Quick question about ADC in a PIC18F04Q41
Woody
PostPosted: Fri Dec 05, 2025 9:13 am     Reply with quote
I am either experiencing a senior moment or I never understood how channel switching for the AD converter works.
Before I elaborate on what the problem is, can I ask: do you need to issue a
set_adc_channel(sAN2);
before every read of an ADC value? Also if I am only interested in on input channel?
Woody
PostPosted: Fri Dec 05, 2025 9:44 am     Reply with quote
Yep, senior moment.
Reading my own question back I noticed the 'sAN2' and thought, that cannot be right....
And indeed, changing this to
set_adc_channel(2);
solved my problem.
My excuses for the stupid question.
PostPosted: Fri Dec 05, 2025 1:43 pm     Reply with quote
don't feel bad.... at 72 ALL my moments are 'senior' !
PostPosted: Sat Dec 06, 2025 12:34 pm     Reply with quote
It is also a very common one.
The sANx designations are used for the setup, to specify which channels
are to be connected to the multiplexer. The set_adc_channel command
then just selects the numbered channel from the multiplexer you want
to read.
I suspect many of us have made that mistake at least once..... Surprised
Woody
PostPosted: Mon Dec 08, 2025 5:05 am     Reply with quote
to read.
Yep.
I used the 'sAN2' designation in the original code, somewhere in the init section. As that did not work I started debugging, using the '2' designation right before the ADC start somewhere else in the code.
That (obviously) made it work but I did not see why until I posted the question. Failing to see the forest for the trees.
What made it a senior moment is that this was not exactly the first time I needed ADC in my code and that usually the ordering of my thoughts when composing a question is enough to see make me see the real problem Embarassed
