CCS PCD "bare metal" C wrappers for polled I2C sla
allenhuffman
PostPosted: Mon Oct 06, 2025 7:56 am     Reply with quote
A few years ago, we found that some of the CCS generated I2C code could lock forever (no deadlock) -- after we were having this happen with some bad I2C stuff.
I started working on converting the polled I2C Slave code over to C routines by looking at the .lst file and recreating what the compiler was generating. The plan was to extend it with deadlock counters or whatever, which I never got around to. (Our coding standard wants only one return in a function, but this first pass was recreating how the assembly worked so it has multiple.)
unsigned int i2cSlaveRead (unsigned int ack)
    uint16_t data;
    data = 0;
    while (1)
        // Wait for start.
        while (S == 0);
        // GCSTAT:
        // Check for broadcast.
        if (GCSTAT == 1)
            // CHECK10BIT:
            // Check for 10-bit addressing.
            if (A10M == 1)
                // CHECK10MATCH:
                // Check for 10-bit address match.
                if (ADD10 == 0)
                    // 10-bit address was not ours. Go back to start.
                    continue;
        // If here, it was either a broadcast, a matching 10-bit address,
        // or our 7-bit address.
    // READ:
    // Wait for receive buffer full.
    while (RBF == 0);
    // READBYTE:
    // Read byte.
    data = I2C3RCV;
    // Check receive overflow flag.
    if (I2COV == 1)
        // CLEAROV:
        // Clear receive overflow flag.
        I2COV = 0;
    // CLOCKRELEASE:
    // Release SCLx clock.
    SCLREL = 1;
    return data;
void i2cSlaveWrite (unsigned int data)
    // START:
    // If no start bit, return.
    if (S == 0) return;
    // GCSTAT:
    if (GCSTAT == 0) return;
    // CHECK10BIT:
    if (A10M == 1)
        // CHECK10MATCH:
        if (ADD10 == 0) return;
    // SEND:
    // Send byte.
    I2C3TRN = data;
    // CLOCKRELEASE:
    SCLREL = 1;
These require the defines of various bits using stuff like this:
// IC2C2STAT - sto(P) bit for status.
#word I2C2STAT = getenv("SFR:I2C2STAT")
#bit TBF = I2C2STAT.0               // bit 0 - transmit buffer full status
#bit RBF = I2C2STAT.1               // bit 1 - receive buffer full status
#bit RW = I2C2STAT.2                // bit 2 - read/write information
#bit S = I2C2STAT.3                 // bit 3 - start
#bit P = I2C2STAT.4                 // bit 4 - stop
#word IFS3 = getenv("SFR:IFS3")
#bit I2C_SYSTEM_BUS_IRQ_PENDING_BIT = IFS3.1    // bit 1 - slave I2Cx IRQ status
...though I do not find the definitions I made for this test slave code, proably because we never got around to completing and using it.
I wanted to ask if someone here has already done this, and might have it somewhere. Eventually I wanted to recreate the master I2C routines as well. This would obviously not be as flexible as what PCD creates, but is a very useful learning tool when bringing up a new engineer on how I2C is actually working.
Anyone?
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
