Frequency limit using SMT gated counter mode
JerryR
PostPosted: Thu Sep 25, 2025 12:44 pm     Reply with quote
This group has helped me a bunch and I'm stuck on this issue:
The setup:
I'm using a PIC16F1619 in gated counter mode as a frequency counter. The microcontroller uses an external 16 MHz crystal. I'm suppling a stable square-wave to C1 (mapped to SMT1SIG), and an external RTCC supplying a stable 1Hz signal (500ms high, 500ms low) to C3 (mapped to SMT1WIN). All signals are square and reliable
The issue:
SMT seems to work in gated counter mode correctly with SMT1SIG input up to around 130,000 Hz. past this limit, frequency is inaccurate. I should be able to count up 2^24 hertz (~16Mhz), however, based on the SMT TIMER's 24 bit width. I'd be happy with half that.
So the problem maybe in the way I'm using the gate signal logic. I should be gating pulses into the timer for 500ms. I should have another 500ms to service the LCD (which should be enough time).
Code attached. Anyone see where I'm going wrong here. Thanks!
#include <16f1619.h>
#use delay(clock=16000000)
#include <flex_lcd.c>
#include <MCP79411_driver.c>
#fuses HS, NOWDT, NOPLLEN, NOPROTECT, NOLVP, NOBROWNOUT
#define SMT_INPUT       PIN_C1   //Signal input pin
#define SMT_GATE_PIN    PIN_C3   // Gate signal pin for SMT
//select pin functions
#pin_select SMT1SIG=SMT_INPUT
#pin_select SMT1WIN=SMT_GATE_PIN
int32 Freq= 0;
int8  hrs,min,sec= 0;
void setup_smt_gated_frequency() {
    // Configure SMT1 module
    // Enable SMT1, select Gated Counter Mode
    // SMT_ENABLED: 1, SMT_MODE_GATED_COUNTER: 10
    setup_smt1(SMT_ENABLED | SMT_MODE_GATED_COUNTER | SMT_WIN_ACTIVE_HIGH);
    // Wait for the peripheral to stabilize
    delay_ms(50);
long measure_frequency()
    long count = 0;
    int8 status;
    smt1_reset_timer();                   //SMT1STAT = 0x00 AFTER
    smt1_start();
     // Reset and start the SMT counter
    while (input(SMT_GATE_PIN) == 0);        //wait here until gate signal goes HIGH
    while (input(SMT_GATE_PIN) == 1);        //wait here until gate signal goes LOW
    // Stop the SMT counter
    smt1_stop();                          ////SMT1STAT = 0x00 AFTER
    // Read the 24-bit SMT counter value
    count = smt1_read(SMT_TMR_REG);
    return count;                             //return count as is SMT_TMR_REG
   long frequency;
   //initialize RTCC
   rtc_Init();
   setup_smt_gated_frequency();
      frequency= measure_frequency();              //measure pulses during gate period (0.5sec)
                                                   //now have approx. 0.5 sec while gate low to service LCD
      lcd_putc("\f");                              //clear screen
      printf(lcd_putc,"%lu",frequency);            //show frequency on LCD
gaugeguy
PostPosted: Thu Sep 25, 2025 2:23 pm     Reply with quote
instead of using long, use int16 or int32 for the variable size depending on what you want.
JerryR
PostPosted: Thu Sep 25, 2025 2:42 pm     Reply with quote
gaugeguy:
ABSOLUTELY! What was I thinking? long truncated results to 16 bits.
Thanks so much
