[Solved]reg_httpServer_cbfunc from Wiznet httpServer library
allenhuffman
PostPosted: Fri Sep 19, 2025 12:53 pm     Reply with quote
A few years ago, I tested a small Wiznet web server on one of our PIC24 boards with the W5500 Wiznet chip.
I am now bringing up a new board with this same W5500 chip and trying it again.
When I include the "httpServer.h", I get these link errors:
*** Error 29 "Wiznet\Internet\httpServer\httpServer.h" Line 107(32,33): Function definition different from previous definition  reg_httpServer_cbfunc Param#1
That line is the prototype:
void reg_httpServer_cbfunc(void(*mcu_reset)(void), void(*wdt_reset)(void));
In the corresponding .c, the function is define exactly the same as far as my eyes can see:
/* Register the call back functions for HTTP Server */
void reg_httpServer_cbfunc(void(*mcu_reset)(void), void(*wdt_reset)(void)) {
    // Callback: HW Reset and WDT reset function for each MCU platforms
    if (mcu_reset) {
        HTTPServer_ReStart = mcu_reset;
    if (wdt_reset) {
        HTTPServer_WDT_Reset = wdt_reset;
The older Wiznet library from some years ago may have been different. We only saved out the W5500 code we were using (no application code) so I do not have any of that old code to look at to see if it was different.
I seem to recall something about function pointers in the CCS compiler that needed to be done differently. Anyone recall?
Cheers,
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
allenhuffman
PostPosted: Fri Sep 19, 2025 3:29 pm     Reply with quote
I found how this issue was dealt with when we did this a few years ago:
Changing functions that take function pointers:
void reg_wizchip_cris_cbfunc(void(*cris_en)(void), void(*cris_ex)(void));
...to use a typedef for the parameters:
typedef void(*CRIS_EN)(void);
typedef void(*CRIS_EX)(void);
void reg_wizchip_cris_cbfunc(CRIS_EN cris_en, CRIS_EX cris_ex);
For anyone working on the current Wiznet W5500 code, they added a few more functions since we originally did this. Here are the typedefs (last few untested, but they compile) so the prototypes and function headers can be updated the same was as that example.
typedef void(*CS_SEL)(void);
typedef void(*CS_DESEL)(void);
typedef iodata_t(*BUS_RB)(uint32_t addr);
typedef void(*BUS_WB)(uint32_t addr, iodata_t wb);
typedef uint8_t(*SPI_RB)(void);
typedef void(*SPI_WB)(uint8_t wb);
typedef void(*SPI_RBB)(uint8_t* pBuf, uint16_t len);
typedef void(*SPI_WBB)(uint8_t* pBuf, uint16_t len);
typedef void(*VOIDPTR)(void);
typedef void(*BUSBUF_RB)(uint32_t AddrSel, iodata_t* pBuf, int16_t len, uint8_t addrinc);
typedef void(*BUSBUF_WB)(uint32_t AddrSel, iodata_t* pBuf, int16_t len, uint8_t addrinc);
typedef void(*QSPI_RB)(uint8_t opcode, uint16_t addr, uint8_t* pBuf, uint16_t len);
typedef void(*QSPI_WB)(uint8_t opcode, uint16_t addr, uint8_t* pBuf, uint16_t len);
