How to pass the PWM stream as a variable?
randy.shaffer
PostPosted: Mon Aug 25, 2025 5:33 pm     Reply with quote
In the example below, I would like to pass the PWM stream as a variable to a function that contains the pwm_set_duty_percent() function.
#include <16F18044.h> // device file
#include <stdint.h> // to use uint
#use delay(internal = 32MHZ)
#use pwm(FREQUENCY = 31.25kHz, PWM_OFF, STREAM = IN2, output=PIN_C2)
#use pwm(FREQUENCY = 31.25kHz, PWM_OFF, STREAM = IN1, output=PIN_C1)
void move_direction(uint8_t const DIRECTION);
int main(void)
  move_direction(IN1);
  move_direction(IN2);
 return(0);
 pwm_set_duty_percent(DIRECTION, 500);
The values of IN1 and IN2 appear to have the values of 2 and 1, respectively. The DIRECTION variable generates the error "A numeric expression must appear here". Compiler is 5.121. Thanks for having a look.
gaugeguy
PostPosted: Tue Aug 26, 2025 5:53 am     Reply with quote
use if ... else or switch inside your move_direction function
PostPosted: Tue Aug 26, 2025 9:36 am     Reply with quote
Yes.
The point is that stream names are preprocessor directives. Solved at
compile time to generate different code. So they always have to be handled
as gaugeguy says by passing your own value, that you then use an if to
select the different possibilities with.
kyleighterry
PostPosted: Fri Aug 29, 2025 4:45 am     Reply with quote
like i mean use if else
