dmendesf
| DSPIC33AK support? |
Posted: Sat Aug 23, 2025 11:03 am |
Does anybody know if CCS support is planned for DSPIC33AK series?
Daniel |
dyeatman
Posted: Sat Aug 23, 2025 2:16 pm |
Looks like a pretty straightforward chip. I personally don't
see anything that might give CCS pause to support it.
Likely they just haven't gotten around to it yet or they
are working on it now. _________________ Google and Forum Search are some of your best tools |
Posted: Sun Aug 24, 2025 5:25 am |
The simple answer here, is ask CCS.
I'd suspect it'll come in a while, but there are quite a few peripheral changes,
and new features, so a lot of coding needed before these can be offered.
Features like these always take the longest' to code, |
dmendesf
Posted: Mon Aug 25, 2025 6:43 am |
| dyeatman wrote: | Looks like a pretty straightforward chip. I personally don't
are working on it now. |
It´s far from straightforward. Instead of fixed 24 bit instructions it has a mixed set of 32 and 16 bits instructions. Working registers have been extended from 16 to 32 bits. It has floating point support.
Only thing to facilitate is that the new instruction set follows the old 24 bit one.
Just sent an email to CCS asking them about it.
Posted: Mon Aug 25, 2025 7:37 am |
Yes, exactly.
It could be 'run' with the standard code support, but taking advantage of
the extensions to the instruction set, and the peripherals will be quite a
lot of work.
It will be a powerful chip when it is supported. |
dmendesf
Posted: Mon Aug 25, 2025 8:20 am |
| Just received an anwer from CCS. They plan to support it but beacause of the different instruction set it will take several months. |
Posted: Tue Aug 26, 2025 9:46 am |
| Much as I expected. |
empty
Posted: Tue Aug 26, 2025 3:00 pm |
May be they will support both, dsPIC33AK and PIC32AK, since they are 32-bit
based CPUs with modified Harvard architecture. |
