How can I use those constant arrays as parameters for a function?
void function(int32 *aux);
writing
function(array_rom1);
complirer doesn't report any error but the data are wrong
thank you
Posted: Fri Jul 25, 2025 2:00 am
What chip?.
It makes a huge difference.
What compiler version?.
Also makes a difference.
The big problem here is trying to use a pointer to ROM. This has been
discussed here many times. The point is that pointers are to the RAM, and
this is a different memory space to the ROM. This is fundamental to the
PIC's Harvard architecture,
You are telling the routine you are passing a pointer to RAM.
Have a look at this thread:
[url]
https://www.ccsinfo.com/forum/viewtopic.php?t=35864
[/url]
You can also switch how const is handled.#DEVICE CONST=ROM, will
make const declarations be handled like ROM declarations.
On the 16bit PIC's you can create a window between the ROM and RAM.
This is 'PSV'. can be enabled with #device.
