rs232 prints rubish
Goto page Previous  1, 2, 3
gaugeguy
PostPosted: Tue Sep 16, 2025 1:17 pm     Reply with quote
That processor uses PPS (peripheral pin select). Please see the sticky on how to use #pin_select
scanan
PostPosted: Wed Sep 17, 2025 12:50 am     Reply with quote
By using
#pin_select U1TX=PIN_C6
#pin_select U1RX=PIN_C7
problem solved
many thanks
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Thu Sep 18, 2025 10:13 am     Reply with quote
A a comment, this line is wrong:
setup_spi(SPI_SS_DISABLED);
This turns off SPI slave select. It does not disable the SPI
allenhuffman
PostPosted: Wed Sep 24, 2025 10:45 am     Reply with quote
I ran into corrupt RS232 output via the ICD debugger on one board which was related to one of the timers. Disabling the timer made the output work.
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Thu Sep 25, 2025 7:56 am     Reply with quote
That's probably because the ICD serial is a software uart, so you need to add the option "DISABLE_INTS" to your #use rs232
Page 3 of 3
