scanan
| rs232 prints rubish |
Posted: Wed May 07, 2025 2:42 am |
Hello
I have a rs232 problem on pic18f45k40
when print some text I get this result
U V W $ Y YZ Y C irmware v1.00
Compiled on
07-May-25
11:20:24
normally I have to get
Firmware v1.00
what could be the problem
compilee ccs 5.115
cheers _________________ Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional. |
Posted: Wed May 07, 2025 4:00 am |
Almost certainly hardware.
Suggests the line is floating, and not pulled up before transmission starts.
Or something else is clocking the line.
How is the physical connection made?.
Does the data repeat the same, or is it different each time?.
How is the power supplied?.
Is this at the start (power on)?.
Is this using a hardware UART, or software serial?. |
scanan
| rs232 problem |
Posted: Wed May 07, 2025 5:57 am |
| Ttelmah wrote: | Almost certainly hardware.
I think no need of pull up for tx pin I did too many project without it never encountered this issue
I am using FTDi232 to connect my board to PC..
settings of UART
#use delay(clock=64000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,RESTART_WDT)
void version(void)
//-- firmware version
printf("Telemmote Receiver\r\n");
printf("Firmware v1.00\r\n");
printf("Compiled on \r\n");
printf(__DATE__);
printf("\r\n");
printf(__TIME__);
printf("\r\n");
delay_ms(250);
printf(__DATE__);
printf("\r\n");
printf(__TIME__);
printf("\r\n");
the first block of pritnt include garbage
but the second print is OK
-the power supply is 10 watt irm-10-12 smps and the feet to and LDO wihich power the PIC with 3.3 volts
-the printed are done after the PIC is configured.
-Hardware UART is used
Joined: 01 Jul 2010 Posts: 9598 Location: Greensville,Ontario
Posted: Wed May 07, 2025 7:14 am |
| get RID of the 'restart WDT' codes and see what happens !!! |
asmallri
Joined: 12 Aug 2004 Posts: 1660 Location: Perth, Australia
Posted: Wed May 07, 2025 11:13 am |
and on pull-ups, these are needed if the line floats. This is why things like
RS485 buffer chips are available in versions that guarantee to flow to the
idle state, and if these are not used the bus dialling should ensure the drive
does this instead.
My thought is that the transmitting PIC line is floating till the UART starts.
Depending on the baud rate and how reset is handled, the result is garbage
preceding the first byte and giving a false start so this too is corrupted. |
scanan
Posted: Thu May 08, 2025 5:42 am |
| temtronic wrote: | | get RID of the 'restart WDT' codes and see what happens !!! |
still the same
when added ERROR nothing changed
I also added a pullup resistor on TX pin no effect
seems the problem is at startup.
After startup anywhere I put a printf there is no problem.
and I get everytime the same garbage everytime I compile
U V W $ Y YZ Y C irmware v1.00 _________________ Dr Suleyman CANAN
scanan
Posted: Thu May 08, 2025 6:17 am |
I finnaly go for a quasi solution
like that
putc(0);
printf("\r\nTelemmote Receiver\r\n");
printf(__DATE__);
printf("\r\n");
printf(__TIME__);
printf("\r\n");
But a problem to be solved. _________________ Dr Suleyman CANAN
Posted: Thu May 08, 2025 6:19 am |
possible help...
1) add PUT to the fuses(Power Up Timer )
2) add a 250ms delay BEFORE the first print code. |
scanan
Posted: Thu May 08, 2025 6:25 am |
| temtronic wrote: | possible help...
Tested but not solve for what you mentioned. _________________ Dr Suleyman CANAN
Posted: Thu May 08, 2025 7:14 am |
May I ask how this connection is actually done???
You say you are using an FTDI adapter. Is this a USB to 5v or USB to
RS232 unit?. If the latter how is your RS232 to 5v adaption done at the PIC?.
This sounds as if you have something like a level shifter that needs to see
the line driven high then low then high again to start working.
Put(0), will send 9bits of 0v, then go high again before the start bit for
your message. This is exactly what is needed to charge up certain types
of inverter based connection. |
asmallri
Posted: Thu May 08, 2025 7:26 am |
| scanan wrote: | | temtronic wrote: | possible help...
Tested but not solve for what you mentioned. |
90% of the time it is the grounding that is the culprit. _________________ Regards, Andrew
Posted: Fri May 09, 2025 12:02 am |
Yes.
The other common things are that standard RS232 drivers using chips like
the MAX232 take significant time for the charge pump to charge up when
power is applied, so PICs can start to send before these are ready, and
some of the USB-RS232 devices instead use 'power stealing' from the
RS232 signals to charge up their supplies. My suspicion is of this later
problem and it actually needs the lines to have cycled from +ve to -ve
to get the voltages established. |
scanan
Posted: Fri May 09, 2025 6:10 am |
| Ttelmah wrote: | Yes.
https://ibb.co/21c0mhGj _________________ Dr Suleyman CANAN
Posted: Fri May 09, 2025 6:42 am |
curious....
you've made several changes so could you please post the program and the printout ?
thanks |
