Minh Lam
| PIC16F77A - ADC resolution |
Posted: Tue May 06, 2025 9:57 pm |
I'm working on the ADC module of PIC16F877A. The schematic is very simple, including a voltage divider connected to RA0: https://uomustansiriyah.edu.iq/media/lectures/5/5_2020_06_14!01_18_34_AM.pdf
What I do not understand is the resolution of the module. The ADC module has 10-bit resolution as read in the datasheet. I was guided that I should put #device ADC = 10 in the code. The real value would be read_adc() * 5/1023 . Everything is fine. My code is as follows:
#include <16f877a.h>
#include <def_877a.h>
#DEVICE ADC=10 //return 10 bit
#fuses HS, NOWDT, NOPROTECT, NOLVP, NODEBUG, NOBROWNOUT, NOCPD, NOWRT
#use delay(clock=8MHz)
#define LCD_RS_PIN PIN_A2
#define LCD_RW_PIN PIN_A3
#define LCD_ENABLE_PIN PIN_A5
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#define LCD_DATA0 PIN_D0
#define LCD_DATA1 PIN_D1
#define LCD_DATA2 PIN_D2
#define LCD_DATA3 PIN_D3
#include <lcd.c>
float voltage;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_2);
while(true) {
set_adc_channel(0);
delay_us(10);
voltage = (read_adc()*5.0)/1023;
lcd_gotoxy(1, 1);
lcd_putc("DHCN");
lcd_gotoxy(1, 2);
printf(lcd_putc, "%1.2fV", voltage);
But when I do not put the directive #device ADC = 10, the voltage must be divided by 65535 to get the correct voltage. OR, I can use ADC = 16 instead (?).
I'd highly appreciate it if someone can explain this. Thank you very much. |
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Wed May 07, 2025 5:28 am |
pretty sure it's the printf format.
"%1.2fV"
to me 1.2 is bad, '1' is total number of digits, '2' is number of digits after decimal point
try '4.2' and see what happens.
The manual isn't very clear about this,2 or 3 more example would be nice. |
EmilyHarris
Posted: Fri May 16, 2025 1:00 am |
| I am replying here so that I can keep track of this thread. |
Posted: Sat May 17, 2025 3:41 am |
Lets make some comments:
First/1023 is wrong. You need /1024. Yes, the ADC has a maximum
reading of 1023, but it reaches this a little before Vref. So the value for
5v, would really be 1024, but the ADC never gives this. There is a graph
given in some of the datasheets of the conversion function, and
Microchip do somewhere have an application note about this.
Then your ADC clock setting is wrong. Datasheet again. For an 8MHz master
clock, you need to use /16. /2 is suitable for a maximum CPU clock rate
of just 1.25MHz. Table 11-1.
Then you don't need to keep reselecting the ADC channel. Select it once
outside the loop.
Jay has already pointed out the problem with your printf format. In C
the number in front of the decimal in printf, is the total field width. The
total number of characters to output, so for x.xx, four characters are
needed. Then the number after the decimal, is obvious, Jay comments
about the poor CCS documentation in this regard, but really the key here
is that this is standard C and is covered in every C textbook.
You'd probably want to slow the loop a little more. Most LCD's can only
update perhaps 4* per second, so taking the delay out to perhaps 200mSec
will work better..
Now on your quateion about the factors and adc=, you can use adc=16,
what happens is as follows:
ADC=8
00000000 VVVVVVVV - top 8 bits of ADC value only
ADC=10
000000VV VVVVVVVV - 10 bit ADC result
ADC=16
VVVVVVVV VV000000 - 10 bit ADC result left justified
So, yes, you can use ADC=16, but it then requires division by 65536
Now on both cases, don't divide!... Multiply instead. In the PIC (and most
other chips without a maths coprocessor), division is a much slower
maths operation, than multiplication. Typically at least four time slower
and resulting in larger code as well.
So instead of using /1024, or /65536, multiply by 0.0009765625, or
0.0000152587. This will result in smaller and faster code.
This also applies to your whole sum. Pre-solve the factor. So 5.0/1024=
0.0048828125
voltage = read_adc()*0.0048828125;
Is more efficient.
However we can go even better, Work in integers instead of float.
In integer, division by binary values (2, 4, 8 etc) is very efficient.
So:
unsigned int16 adc_val;
delay_ms(250); //most LCD's require at least 90mSec before they
//can be initialised
setup_adc(ADC_CLOCK_DIV_16);
set_adc_channel(0);
delay_ms(200);
adc_val=read_adc();
adc_val=(adc_val*31)+(adc_val/4); //Gives *31.25 very efficiently
lcd_gotoxy(1, 1);
lcd_putc("DHCN");
lcd_gotoxy(1, 2);
printf(lcd_putc, "%4.2lw", (adc_val/64));
*31.25/64 = 0.48828125 this is 100* 5/1024, so gives an integer in
hundredths of a volt. %4.2lw displays an integer as x.xx |
Posted: Tue May 20, 2025 8:22 am |
I just wanted to note that division is ok for this instance as long as it is a power of 2 (1024, 65536, etc), which as Ttelmah noted you should be doing instead of 1023, etc.
Division by values that are powers of 2 generally get optimized into shift operations which are very fast.
You can see an example of this here:
.................... value = read_adc();
00214: BCLR.B 320.0
00216: BSET.B 320.1
00218: BTSS.B 320.0
0021A: BRA 218
0021C: PUSH 300
0021E: POP 1002
.................... value = value / 1024;
00220: MOV 1002,W0
00222: LSR W0,#A,W0
00224: MOV W0,1002
The same applies for the % operator (modulus). Doing this where the 2nd operand is a power of 2 optimizes down to an AND operation:
.................... value = value % 256;
00226: MOV 1002,W4
00228: AND #FF,W4
0022A: MOV W4,1002
