about WDT on pic18f45k40
scanan
PostPosted: Fri Apr 25, 2025 6:48 am     Reply with quote
hi
I am a bit confused
in the pic18f45k40.h WDTCLK_HFINTRC is defined in the fuses
but in the datasheet page 34 nothing mentioned about it?
any suggestions
my fuse definition in my prog is as follows
#FUSES NOEXTOSC,RSTOSC_HFINTRC_64MHZ //1
//#FUSES //2
#FUSES NOCLKOUT,NOCKS//3
#FUSES NOFCMEN,NOMCLR,PUT,NOLPBOR,NOBROWNOUT //4
//#FUSES //5
#FUSES ZCDDIS,NOPPS1WAY,NOSTVREN //6
#FUSES NODEBUG,NOXINST,WDT1024 //7
//#FUSES //8
//#FUSES //9
#FUSES NOWDT,WDT_SW//10
//#FUSES //11
#FUSES WDTCLK_HFINTRC//12
#FUSES NOWRT,NOWRTC,NOWRTB,NOWRTD //13
#FUSES NOSCANE,NOLVP,PROTECT,CPD//14
#FUSES NOEBTR,NOEBTRB //15
what clock source would be for the wdt ?
one thing
--- More info: Fuses changed for this oscillator setting
after compiling I get this info
cheers
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Sat Apr 26, 2025 10:31 am     Reply with quote
You don't show us what 'information' you get after compiling.
Do you have a setup_wdt line in the code?. If so, this will override the
fuse clock selections. Basically the wdt timings can only be set in the
fuses, so if you specify a time in the code, the compiler changes the
fuses to match this setting.
scanan
PostPosted: Wed May 07, 2025 2:38 am     Reply with quote
THanks
I forgot the setup_wdt
now works well
Dr Suleyman CANAN
