GAMCH96
| PROBLEM INTERFACE DHT22 PIC16F876 |
Posted: Thu Aug 21, 2025 11:02 am |
Good morning!!
In this case, I want used DHT22 Sensor and Driver DHT22.C . the data obtained in this program is incorrect.
Could you help, place?
//This is DHT22.C Libary Used:
#define dht22 PIN_A2
#bit dht_io = 0xf92.2
byte dht22_dat[5];
byte leer_datos_dht();
Void dht_init (void){
dht_io=0;
delay_ms(1);
output_high(dht22);
byte leer_datos_dht(){
byte i = 0;
byte result=0;
for (i=0; i< 8; i++) {
//We enter this during the first start bit (low for 50uS) of the byte
//Next: wait until pin goes high
while(input(dht22)==0);
delay_us(30);
if (input(dht22)==1){//Was: if(PINC & _BV(dht_PIN))
result |=(1<<(7-i));
while (input(dht22)==1);
//Was: while((PINC & _BV(dht_PIN)));
}//end of "for.."
return result;
Void leer_dht22 (float &dhthum,float &dthtemp){ //byte GlobalErr=0;
byte dht22_in, i, dht22_checksum;
int16 temperatura, humedad;
float temp,hum;
dht_io=0; // configurar el pin como salida
output_high(dht22);
delay_us(20);
output_low(dht22);
delay_ms(18);
output_high(dht22);
delay_us(22);
dht_io=1;// configurar el pin como entrada
delay_us(5);
dht22_in=input(dht22);
if(dht22_in) {
//GlobalErr=1;
printf("\r\ndht condicion 1 de inicio no encontrada");
return;
delay_us(80);
if(!dht22_in){
//GlobalErr=2;
printf("\r\ndht condicion 2 de inicio no encontrada");
return;
delay_us(80);
for (i=0; i<5; i++){
dht22_dat[ i ] = leer_datos_dht(); // capturando datos
dht_io=0;
delay_us(10);
output_high(dht22);
dht22_checksum= dht22_dat[0]+dht22_dat[1]+dht22_dat[2]+dht22_dat[3];
if(dht22_dat[4]!=dht22_checksum){
//GlobalErr=3;
printf("\r\nDHT checksum error");
humedad = make16(dht22_dat[0],dht22_dat[1]);
temperatura = make16(dht22_dat[2],dht22_dat[3]);
hum = humedad;
temp = temperatura;
dhthum = (hum)/100;
dthtemp = (temp)/100;
//Test Code for a Microntroller PIC16F876 :
//LCD module connections PUERTO B
#define LCD_RS_PIN PIN_B0
#define LCD_RW_PIN PIN_B1
#define LCD_ENABLE_PIN PIN_B2
#define LCD_DATA4 PIN_B3
#define LCD_DATA5 PIN_B4
#define LCD_DATA6 PIN_B5
#define LCD_DATA7 PIN_B6
//End LCD module connections
#include <16F876.h>
#use delay(clock = 8000000)
#use rs232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7) // Tx a 9600 BAUDS VIA RS-232 STANDAR
#include "dht22.c"
#include <lcd4x20b.c>
#use fast_io(A)
// Connection pin between PIC16F877A and DHT11 (RHT01) sensor ENTRADA RA0
#BIT Data_Pin = 0x05.0 // Pin mapped to PORTA.0
#BIT Data_Pin_Direction = 0x85.0 // Pin direction mapped to TRISA.0
//Pal bootloader
#build (reset=0x1000,interrupt=0x1008)
#org 0x0000,0x0FFF{}
void main(){
//int16 lux;
float dhthum, dthtemp;
lcd_init();
lcd_putc("\fSensor T-H\nDHT22 RHT03");
printf ("\f\r\nSensor de temperatura y humedad:\r\nDHT22-RHT03");
//printf(lcd_putc,"\fHola-Saludos\nEnviame un dato");
dht_init();
delay_ms(300);
lcd_putc("\f");
while(true){
//set_adc_channel(0);
//delay_ms(1);
// lux=read_adc();
// printf("\r\nAdc =: %lu ",lux);
//delay_ms(10);
//leer_dht();
leer_dht22(dhthum, dthtemp);
// sht21_both(temp,humid);
delay_ms(10);
lcd_putc('\f'); // LCD clear
lcd_gotoxy(1, 1); // Go to column 1 row 1
printf(lcd_putc, "RH = %f %%",dhthum); // Display message1
lcd_gotoxy(1, 2); // Go to column 1 row 2
printf(lcd_putc, "Tem = %f %cC", dthtemp,223); // Display message2
printf("\r\nDHT22 RH = %f %%",dhthum);
delay_ms(1);
printf("\r\nDHT22 Temp = %f %cC", dthtemp,223);
delay_ms(1);
delay_ms(2000);
Joined: 01 Jul 2010 Posts: 9598 Location: Greensville,Ontario
Posted: Fri Aug 22, 2025 8:19 am |
1st step..
dump out the RAW data from the sensor and YOU decode the data into real temperature and humidity. That way you'll know if it's the sensor or the 'math' that the PIC program is doing. |
GAMCH96
Posted: Fri Aug 22, 2025 9:35 am |
Thank you..with pleasure.. I will verify it and check it..thank you....  |
Posted: Sat Aug 23, 2025 3:09 am |
There are fundamental faults with what is being done.
You don't want to pull the DHT22 signal high. This needs to be done
by an external pull-up resistor. The signal should be wired so it floats high.
The PIC then pulls this wire low, waits, and then lets the line float so the
sensor can take control of the wire. Pulling it high, the two chips will
fight one another.
The DHT is an open-collector output drive device.
The sequence should be:
output low on the signal
wait >1mSec
output float the signal (you can do this by driving high, and then
reading immediately).
You then read the signal from the DHT.
Do you have a pull up resistor?. It won't work unless you have.
Also, you do not tell us your processor clock rate?. The method you are
using to generate the bit mask for the data is very slow. This could
easily be taking too long, and then the samplign will not be at the right
place in subsequent bits.
Then the actual sampling is wrong. Whether a bit is 1 or 0 depends on the
_length_ of the high signal after the 50iSec low pulse. If it is about 30uSec
the bit is a 0 if it is around 70uSec, the bit is a 1. You therefore need to
be reading the level about 60uSec after the rising edge. If the signal is
high at this point it is a 1 otherwise a 0. |
GAMCH96
| INTERFACE DHT11 PIC16F876 PLACE I HAVE PROBLEM MESUREMENT |
Posted: Mon Aug 25, 2025 10:16 am |
Good morning!!
Following on my email, and after several attempts, I believe I've successfully connected the DHT11 to the PIC16F876.
I want used el DHT11 Library.
I found a code written in CCS Compiler
My problem is that measurement digits are not changing...?
I using the drive DHT11.C -… command incorrectly? I don't know???
This is the using code……..
A. This is DHT11.h Functions:
#define DHT11_pin PIN_A0
unsigned char values[5];
void DHT11_init();
unsigned char get_byte();
unsigned char get_data();
B. This is DHT11.C Libary Used:
#include "DHT11.h"
void DHT11_init()
output_float(DHT11_pin);
unsigned char s = 0;
unsigned char value = 0;
for(s = 0; s < 8; s += 1)
value <<= 1;
while(!input(DHT11_pin));
delay_us(30);
if(input(DHT11_pin))
value |= 1;
while(input(DHT11_pin));
return value;
short chk = 0;
unsigned char check_sum = 0;
output_high(DHT11_pin);
output_low(DHT11_pin);
delay_ms(18);
delay_us(26);
chk = input(DHT11_pin);
if(chk)
return 1;
delay_us(80);
if(!chk)
return 2;
delay_us(80);
for(s = 0; s <= 4; s += 1)
values[s] = get_byte();
for(s = 0; s < 4; s += 1)
check_sum += values[s];
if(check_sum != values[4])
return 3;
return 0;
C. Code for a Microntroller PIC16F876 :
#include <16F876.h>
#include "DHT11.c"
#use fast_io(A)
const unsigned char symbols[8]={0x07, 0x05, 0x05, 0x07, 0x00, 0x00, 0x00, 0x00};
void setup();
void lcd_symbols();
unsigned char state = 0;
setup();
state = get_data();
switch(state)
case 1:
lcd_gotoxy(1, 1);
lcd_putc("Tmp/ C: ");
lcd_gotoxy(5, 1);
lcd_putc(0);
lcd_gotoxy(1, 2);
lcd_putc("R.H/ %: ");
lcd_gotoxy(9, 1);
printf(lcd_putc, "%3u.%02u ", values[2], values[3]);
lcd_gotoxy(9, 2);
printf(lcd_putc, "%3u.%02u ", values[0], values[1]);
delay_ms(10);
printf("%3u.%02u ", values[2], values[3]);
printf("%3u.%02u ", values[0], values[1]);
printf("\n\r"); // Display message2
void setup()
disable_interrupts(global);
port_B_pullups(FALSE);
setup_timer_0(T0_internal | T0_8_bit);
set_timer0(0);
DHT11_init();
lcd_init();
lcd_putc("\f");
lcd_symbols();
void lcd_symbols()
unsigned char i = 0;
lcd_send_byte(0, 0x40);
for(i = 0; i < 8; i++)
lcd_send_byte(1, symbols[i]);
lcd_send_byte(0, 0x80);
Can you help me, Please…
Thank you.
Gustavo Adolfo Martinez Chavez. |
Posted: Tue Aug 26, 2025 9:45 am |
Try first extending your delay to perhaps 40uSec. 30uSec is right on the
minimum the chip specifies.
Then your reading code as posted is wrong. It'll exit before erasing the
8 bits.
Use the code buttons, it makes it very hard to see the layout of your
code. but the get_byte routine as posted looks wrong. |
