HS ADC Interrupt problem.
drkome
PostPosted: Fri Mar 21, 2025 5:29 am     Reply with quote
Hello, I want to adc read from adc interrupt.
void OPAMP_Init(){
         ADCON1  = 0x03E0;
         ADCON2  = 0x0104;
         ADCON3  = 0x0004;
         ADCHS   = 0x0023;
         ADCSSL  = 0x0000;
         ADPCFG  = 0xFFFF;
         IFS0    = IFS0 & 0xF7FF;
         IEC0    = IEC0 | 0x0800;
         ADCON1 = ADCON1 | 0x8000;
#int_ADC1
void adc1_isr(void) {
     currentOpamp.a = ADCBUF0; // AN0 sonucu
     currentOpamp.b = ADCBUF1; // AN1 sonucu
     currentOpamp.c = ADCBUF2; // AN2 sonucu
     output_d(0b1100);
     IFS0 = IFS0 & 0xF7FF ;  //kesmyi s�f�rla
Did I do something wrong? I want to program one that normally works with pwm synchronization for FOC control. But I wrote something like this for the beginning. There are many for mplab on the internet, but I want to do it in ccs c. Interrupt does not jump. I even wrote output_d command to turn on the led. Thank you for your answers.
PostPosted: Fri Mar 21, 2025 6:24 am     Reply with quote
quik comments...
you need to post which PIC you're using,
as well as compiler version
and of course the main() program. well the beginning , to see IF you've enabled the ADC interrupt.
drkome
PostPosted: Fri Mar 21, 2025 6:41 am     Reply with quote
ahh sorry I forgot to say them. I am using dsPIC30F4011. Complier version V5.113.
 void main(){
  OPAMP_Init();
  while (1) {
      fprintf(RS232,"DEGER1 = %d \n\r" ,currentOpamp.a);
      fprintf(RS232,"DEGER2 = %d \n\r" ,currentOpamp.b);
      fprintf(RS232,"DEGER3 = %d \n\r" ,currentOpamp.c);
PostPosted: Fri Mar 21, 2025 8:09 am     Reply with quote
You have not got the ASAM bit on, so the chip won't start sampling on it's
own. You then don't set SAMP, so no sampling will actually start. The
synchronise bit to the PWM, stope sampling when this trigger is seen and
then performs the conversion, but something has to actually start the
sampling first for this to happen. You are not setting anything to do this.....
Also in what you post, there is no sign of the interrupt being enabled, or the
global enable being set, so no interrupt would happen.
drkome
PostPosted: Sun Mar 23, 2025 3:36 am     Reply with quote
Ah okay I will try this tomorrow. I need to read lowside current from adc with interrupt for FOC control for BLDC. Thanks for answering.
