Marco27293
| DSPIC33EP512GP502 -- PCD v5.115 compiler - Bootloader issue |
Posted: Thu Feb 20, 2025 1:55 pm |
I'm using this bootloader code. It seems to work fine.
//// EX_PCD_BOOTLOADER.C ////
//// This program is an example standalone bootloader. ////
//// This program must be loaded into a target chip using a device ////
//// programmer. Afterwards this program may be used to load new ////
//// versions of the application program. ////
//// This bootloader is designed to detect a pushbutton low on reset. ////
//// It will then use the RS232 link to download a new program. ////
//// Otherwise the application program is started. ////
//// Use an RS232 link and the SIOW.EXE program to load a new HEX ////
//// file into the target chip. See example EX_PCD_BOOTLOAD.C. ////
//// Uncomment the define BOOTLOADER_MODE2X to use an alternate ////
//// bootloader that receives each line in the hex file twice and ////
//// compares them before acknowledging the line and writing it to ////
//// the target chip's memory. This mode only works with the ////
//// CCS_BOOTLOADER.exe program, add MODE2X to the command line to ////
//// use this mode. ////
//// The config bits will be write protected, in software, by the ////
//// rom_modify() function. To allow config bits to change then ////
//// you need to #define ROM_WRITE_CAN_MODIFY_CONFIG_BITS ////
//// Depending on the PIC the bootloader is being built for or if ////
//// changes are made to the code the bootloader may not fit in the ////
//// program memory set a side for it by default for this example. ////
//// If that happens the size set aside for the bootloader can be ////
//// changed by defining LOADER_PAGES to the number of erase pages ////
//// to set aside for it before the pcd_bootloader.h is included, ////
//// this define must be made in both the bootloader and application ////
//// programs for the bootloader to work correctly. ////
//// This example will work with the PCD compiler. Change the ////
//// device, clock, push button, and RS232 pins for your hardware if ////
//// needed. ////
//// (C) Copyright 1996,2021 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
//// http://www.ccsinfo.com ////
// see explanation above
//#define ROM_WRITE_CAN_MODIFY_CONFIG_BITS
#include <33EP512GP502.h>
#FUSES NOPROTECT // Allow a Programmer device (eg. Pickit) to read Microcontroller firmware
#FUSES NOIOL1WAY // Used to enable peripheral deselection (useful to reduce power-consumption )
#use delay(internal=20MHz,clock_out)
#define UART_2_TX PIN_B11 // DsPIC UART2 TX
#define UART_2_RX PIN_B12 // DsPIC UART2 RX
#PIN_SELECT U2TX=UART_2_TX
#PIN_SELECT U2RX=UART_2_RX
#use rs232(uart2,baud=115200,PARITY=N, BITS=8, ERRORS, stream=SPECTRUM)
#define _bootloader
#define BOOTLOADER_MODE2X
#define BOOTLOADER_STREAM SPECTRUM
#define LOADER_PAGES 5
#include <pcd_bootloader.h>
#include <loader_pcd.c>
delay_ms(140); // wait for PLL
char ans='0';
do
ans=fgetc(SPECTRUM);
while(ans!='A'&&ans!='K'&&ans!='!');
if(ans=='!')
fputc('!',SPECTRUM);
load_program();
else if(ans=='K')
fputc('K',SPECTRUM);
goto_address(APPLICATION_START); // Salta all'applicazione se non deve entrare in modalità bootloader
#int_default
void isr(void)
jump_to_isr(APPLICATION_ISR_START);
It seems to work fine, it loads correctly an application but I'm experiencing a strange issue related to INT_EXT1:
#INT_EXT1
void MCP346_manager()
switch(sample_num)
case 16384:
disable_interrupts(INT_EXT1);
clear_interrupt(INT_EXT1);
sample_num++;
default:
// 1. SPI Read ADC
input_buffer[shift] = make16(spi_read(0xFF),spi_read(0xFF));
// 2. Aggiorna l'indice del buffer circolare (utilizzando maschera per efficienza)
shift = (shift + 1) & TAP_MASK;
// 3. Aggiorna la somma parziale per il passo corrente
switch(sample_num&7)
case 0:
acc_sum += _mul(fir[0], input_buffer[(shift - 0) & TAP_MASK ]);
acc_sum += _mul(fir[1], input_buffer[(shift - 1) & TAP_MASK ]);
acc_sum += _mul(fir[2], input_buffer[(shift - 2) & TAP_MASK ]);
acc_sum += _mul(fir[3], input_buffer[(shift - 3) & TAP_MASK ]);
case 1:
acc_sum += _mul(fir[4], input_buffer[(shift - 4) & TAP_MASK ]);
acc_sum += _mul(fir[5], input_buffer[(shift - 5) & TAP_MASK ]);
acc_sum += _mul(fir[6], input_buffer[(shift - 6) & TAP_MASK ]);
acc_sum += _mul(fir[7], input_buffer[(shift - 7) & TAP_MASK ]);
case 2:
acc_sum += _mul(fir[8], input_buffer[(shift - 8) & TAP_MASK ]);
acc_sum += _mul(fir[9], input_buffer[(shift - 9) & TAP_MASK ]);
acc_sum += _mul(fir[10], input_buffer[(shift - 10)& TAP_MASK ]);
acc_sum += _mul(fir[11], input_buffer[(shift - 11)& TAP_MASK]);
case 3:
acc_sum += _mul(fir[12], input_buffer[(shift - 12)& TAP_MASK ]);
acc_sum += _mul(fir[13], input_buffer[(shift - 13)& TAP_MASK ]);
acc_sum += _mul(fir[14], input_buffer[(shift - 14)& TAP_MASK ]);
acc_sum += _mul(fir[15], input_buffer[(shift - 15)& TAP_MASK ]);
case 4:
acc_sum += _mul(fir[16], input_buffer[(shift - 16)& TAP_MASK ]);
acc_sum += _mul(fir[17], input_buffer[(shift - 17)& TAP_MASK ]);
acc_sum += _mul(fir[18], input_buffer[(shift - 18)& TAP_MASK ]);
acc_sum += _mul(fir[19], input_buffer[(shift - 19)& TAP_MASK ]);
case 5:
acc_sum += _mul(fir[20], input_buffer[(shift - 20)& TAP_MASK ]);
acc_sum += _mul(fir[21], input_buffer[(shift - 21)& TAP_MASK ]);
acc_sum += _mul(fir[22], input_buffer[(shift - 22)& TAP_MASK ]);
acc_sum += _mul(fir[23], input_buffer[(shift - 23)& TAP_MASK ]);
case 6:
acc_sum += _mul(fir[24], input_buffer[(shift - 24)& TAP_MASK ]);
acc_sum += _mul(fir[25], input_buffer[(shift - 25)& TAP_MASK ]);
acc_sum += _mul(fir[26], input_buffer[(shift - 26)& TAP_MASK ]);
acc_sum += _mul(fir[27], input_buffer[(shift - 27)& TAP_MASK ]);
case 7:
acc_sum += _mul(fir[28], input_buffer[(shift - 28)& TAP_MASK ]);
acc_sum += _mul(fir[29], input_buffer[(shift - 29)& TAP_MASK ]);
acc_sum += _mul(fir[30], input_buffer[(shift - 30)& TAP_MASK ]);
acc_sum += _mul(fir[31], input_buffer[(shift - 31)& TAP_MASK ]);
samples32[sample_num>>3] =(acc_sum);
acc_sum = 0;
// 4. Incrementa il contatore dei campioni acquisiti
sample_num++;
This ISR is defined in the application.
It is used to sample and filter data from ADC connected to DSPIC via SPI1.
The problem is: when I execute the standalone application without bootloader all is fine and I'am able to sample data at the required Fsampling.
When the application is embedded with the bootloader part the isr still works but I reach exactly Fsampling/2.
The Fuses and clock for bootloader and application are the same:
//From LST:
Configuration Fuses:
Word 3L: FFCF ICSP1 NOJTAG NODEBUG
H: 0000
Word 4L: FFFF NOALTI2C1 NOALTI2C2 WDTWIN_25%
H: 0000
Word 5L: FF7F WPOSTS16 WPRES128 PLLWAIT WINDIS NOWDT
H: 0000
Word 6L: FFDF NOPR NOOSCIO NOIOL1WAY
H: 0000
Word 7L: FFF9 FRC_PLL IESO
H: 0000
Word 8L: FFFF NOWRT NOPROTECT
H: 0000
Word 9L: FFFF
H: 0000
Word 10L: FFFF
H: 0000
Could you help me to find the problem cause ?
The ADC is configured by this driver:
//-----------------------------MCP346x Driver.C-------------------------------//
#ifndef __MCP346_C
#define __MCP346_C
#include "MCP346.h"
//-----------------------------Foos Definitions-------------------------------//
//MCP346 Utility implemented via SPI
unsigned int16 MCP346_Spi_Util(unsigned int8 mode)
unsigned int8 MSB=0,LSB=0,LOCK=0,ADC_REG_CHECK=0,ADC_SETTING_SUM=0;
output_bit(SPI1_PIN_SELECT,1);
output_bit(SPI1_PIN_SELECT,0);
switch(mode){
case _full_reset:
spi_read(0b01111000); //full reset
case _start_adc:
spi_read(0b01101000); //start conversion
case _single_read:
spi_read(0b01000001); //Static Read ADCDATA register
MSB=spi_read(0xFF);
LSB=spi_read(0xFF);
return make16(MSB,LSB);
case _read_lock:
spi_read(0b01110101); //read lock
LOCK=spi_read(0xFF);
return (unsigned int16)(LOCK);
case _config_lock:
spi_read(0b01110110); //Incremental write lock register
spi_read(0xA5);
case _config_adc:
spi_read(0b01000110); //Incremental write starting at 0x01 config0
spi_read(0b11000010); //Config0 external clock without output,Standby mode
spi_read(0b00001000); //Config1 MCLK
spi_read(0b10101011); //Config2
spi_read(0b11000000); //Config3, 16 bit format data
spi_read(0b01110010); //IRQ
spi_read(0b00010000); //MUX select channel CH1 - CH0
case _read_adc:
spi_read(0b01000111); //Incremental read starting at 0x01 config0
ADC_REG_CHECK=spi_read(0xFF); //Config0 external clock without output,Conversion mode
ADC_REG_CHECK ^= 0b11000010;
ADC_SETTING_SUM+=ADC_REG_CHECK;
ADC_REG_CHECK=spi_read(0xFF); //Config1 MCLK
ADC_REG_CHECK ^= 0b00001000;
ADC_REG_CHECK=spi_read(0xFF); //Config2
ADC_REG_CHECK ^= 0b10101011;
ADC_REG_CHECK=spi_read(0xFF); //Config3, 16 bit format data
ADC_REG_CHECK ^= 0b11000000;
ADC_REG_CHECK=spi_read(0xFF); //IRQ
ADC_REG_CHECK ^= 0b01110010;
ADC_REG_CHECK=spi_read(0xFF); //MUX select channel CH1 - CH0
ADC_REG_CHECK ^= 0b00010000;
if(ADC_SETTING_SUM==0)
return MCP_SUCCESS;
return MCP_FAILURE;
return MCP_SUCCESS;
//MCP346 Restart
void MCP346_Restart()
delay_ms(50);
MCP346_Spi_Util(_full_reset);
delay_ms(50);
do
MCP346_Spi_Util(_config_lock);
delay_ms(50);
while(MCP346_Spi_Util(_read_lock) != MCP_LOCK);
delay_ms(50);
do
MCP346_Spi_Util(_config_adc);
delay_ms(50);
while(MCP346_Spi_Util(_read_adc) != MCP_SUCCESS);
delay_ms(50);
MCP346_Spi_Util(_start_adc);
#endif
Changing driver options I'am able to reach correct Fsampling, but WHY must be a mismatch in registers configurations between application standalone and Boootloader+application ?
Nothing changes in my code except for application:
they are commented in standalone project... |
Posted: Fri Feb 21, 2025 3:53 am |
Hmm.
That is odd.
One comment, you don't need the clear_interrupt lines in your interrupt
handler. Unless you compile an interrupt with the setting 'NOCLEAR', the
interrupt is always cleared when the handler exits. So you are potentially
clearing the interrupt twice.
Your remark on the NOIOL1WAY setting is wrong. This is what allows
your main code to have #PIN_SELECT lines that work. The power control
options are separate to this.
Using the bootloader, adds a tiny extra delay in handling the interrupts.
This can be avoided on chips that support the alternate interrupt vector
table, by using this. Look at the AIVT bootloader and boatload examples.
Check that the fuse settings given by the compile when boot loading, match
those you get from the bootloader. You show one set, but not the other.
Are there any other interrupts in use?.
Just a silly thing to try. Compile both the bootloader and the application
with #OPT 0
There was a problem around your compiler version with the default
optimisation making some interrupts not work properly. I'm wondering
if you might be experiencing this. |
Marco27293
Posted: Fri Feb 21, 2025 6:16 am |
Thank you Ttelmah,
I'll try #OPT 0 ASAP.
Meanwhile some clarifications:
- Fuses match between bootloader and application (No change)
- No other interrupt required or used
I looked AIVT bootloader and bootload examples in pcd compiler folder.
But seems that chip dspic33ep512gp502 I'm using dors not supporto the required Fuses...
How can I use alternate interrupt Vector on this chip ?
Any workaround or fix ? |
Posted: Fri Feb 21, 2025 7:39 am |
Unfortunately it looks like your chip does not support this.
As a coment, the interrupt handling with the bootloader present will have
one extra ijump instruction before being handled. Now you have several things
that could be optimised better, so these might make the difference.
Don't use a switch for handling the single first test. Just test if and else for
the other code. Get rid of the clear interrupts as already mentioned and
the handling speed will probably be as good. |
Marco27293
Posted: Sat Feb 22, 2025 5:51 am |
I used #OPT 0 in both bootloader and bootload application.
I removed clear interrupt from isr code and replaced the first switch with if else statement.
#OPT 0
#include <dsp_data_util.c>
//#include <pcd_traps.c> // Include for Debug: Modify TrapPutc(char c) using "fputc(c, SPECTRUM);" in both cases
//--------------------------3Bee Library--------------------------------------//
#include <Lib/main.h>
#include <Lib/fft_3Bee.h>
#include <Lib/MCP346.c>
#include <Lib/myFIR.h>
//-----------------------------ISRs Definitions-------------------------------//
//External ISR used to acquire data from ADC
#INT_EXT1
if(sample_num==16384)
sample_num++;
// 1. SPI Read ADC
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
acc_sum = 0;
sample_num++;
Problem persists. I have now a weird output not a signal equal to Fsampling/2 but an unstable Fsampling... |
Joined: 01 Jul 2010 Posts: 9587 Location: Greensville,Ontario
Posted: Sat Feb 22, 2025 6:11 am |
FWIW, I don't use that PIC but...
is there any chance it's a memory boundary issue ? You've got several included files of unknown size...maybe with the bootloader code you 'cross a boundary ' ??
Maybe try the '1 Hz LED' program and see if it works 100% without/with bootloader. if it does, then add those 'included files', recompile, test again.
Having 'weird' stuff like wrong sampling sounds like possible 'corrupted memory' issue. |
Marco27293
Posted: Sat Feb 22, 2025 6:36 am |
I don' t think It could be a Memory issue...
Bootloader occupies 1% Rom program Memory and 9% RAM in worst case.
Application occupies 2% Rom program Memory and 46% RAM in worst case.
Please help me to fix this... |
Marco27293
Posted: Sat Feb 22, 2025 7:16 am |
I also monitored isr execution time in application standalone code.
It is ok, isr needs few microseconds less than period required to reach Fsampling. |
Posted: Sat Feb 22, 2025 12:33 pm |
The memory Jay was talking about, is not memory size, but boundaries.
It could be a problem. Try rebuilding everything using 8 for the number of
pages. I know this means you will lose some size, but the point is you
are putting the location of the boot onto n odd page boundary. Something
that never normally happens. |
Marco27293
Posted: Sun Feb 23, 2025 2:22 am |
I used:
#OPT 0
#define LOADER_PAGES 8
also with even (8) loader_pages both in bootloader and bootload application code, problem persists...
It seems that only half external interrupt events are processed by isr, like something is going wrong in clearing the interrupt flags and registers... I mean using standalone application I reach Fsampling, using application+bootloader I get exactly Fsampling/2...
If I set ADC registers in order to reach Fsampling*2, in application+bootloader I get correct Fsampling, BUT I need to understand and fix the problem in order to sample a correct signal without any doubt.
What could try to fix the problem ? |
Posted: Sun Feb 23, 2025 7:46 am |
I think you need to talk to CCS about this.
There have been a couple of threads recently with interrupt problems when
using a bootloader. That these have suddenly appeared, raises the suspicion
that something in the handling of the interrupts is faulty in the current
implementation. I haven't used a bootloader for a long time, but the
handling when I looked at it seemed to be OK in the past. |
Marco27293
Posted: Sun Feb 23, 2025 3:13 pm |
Thank you!
I wrote to technical support, I hope they'll help me to get rid of this weird issue.
Meanwhile could you share me links to threads related to similar problem with bootloader ? I would like to understand better what is happening...
Do you think that manually set/clear specific registers bits in isr code, could fix the problem ?
Any further suggestions ?
Posted: Sun Feb 23, 2025 4:27 pm |
| can you try the '1Hz LED' program and see if it fails ? |
Marco27293
Posted: Mon Feb 24, 2025 1:33 am |
I verified with LED debugging that isr is executed at correct timing.
It seems a memory boundary issue related to contemporary use of bootloader and FFT library:
#include <Lib/fft.h>
If I avoid to process data and compute FFT I get the attended signal.
Now I have to find a way to make work together fft and bootloader code, I need both!
CCS FFT.h removed.
Do not post the copyright library code in the forum please. |
Posted: Wed Feb 26, 2025 2:00 am |
That makes sense.
We were starting to think it might be the something with memory layout.
When I get a chance, I'll have a look at the FFT library. Must admit I've
only done FFT with much larger/faster chips, and ended up writing my
own code for this. However very busy at the moment, so doubt if I'll
get to it soon....
Please post details of how you setup the buffer for the FFT, and the calls
to the FFT library. |
