Makiwa
UDP Packet Loss Issue in Embedded Project with CCS C and PIC |
Posted: Fri Feb 21, 2025 8:45 am |
I am currently working on an embedded project using the CCS C compiler for a PICmicro microcontroller. I've configured the system to use communication over an Ethernet network, but I'm encountering an issue when managing UDP packets. When attempting to send a UDP packet to a remote server, it seems like there's packet loss or an unusually long response delay.
I've checked the network configuration and the TCP/IP stack, but I can't clearly pinpoint the cause of the problem. If anyone has faced a similar issue or has suggestions on optimizing UDP packet handling in this context, I would greatly appreciate your input!
https://cyberopti.com/optimisez-votre-reseau-avec-vrf-virtual-routing-and-forwarding/
Thank you in advance for your help!
Posted: Fri Feb 21, 2025 10:43 am |
You need to give a lot more information. There are so many generations of
PIC, that knowing which chip is vital.
Then how is the Ethernet being handled?. Internal Ethernet peripheral,
or an external chip?. how is the Ethernet connected?. Is this a local
network, or going via the internet?. How long are the packets?. |
asmallri
Joined: 12 Aug 2004 Posts: 1659 Location: Perth, Australia
Re: UDP Packet Loss Issue in Embedded Project with CCS C and |
Posted: Thu Feb 27, 2025 2:12 am |
Makiwa wrote: | Hello,
Thank you in advance for your help! |
UDP does not have a reliable transport layer (that is what TCP provides). When you use TCP an application's TCP stack is able to detect and recover from errors. When there is a low packet rate loss, the user will often not know that packet loss has occurred.
When using UDP, there is no network stack recovery therefore even a low packet loss rate will result in the user or application having an issue. If your forwarding path includes an Ethernet hub anywhere along the path then packet loss is a fact of life.
What this also means for custom hardware, if you have a hardware fault / design flaw that results in corrupt packets, TCP may appear to work fine but UDP will not. To test your hardware is functioning correctly, try using TCP with a packet sniffer and see if packet retransmissions are occuring indicting a hardware issue. _________________ Regards, Andrew
Posted: Thu Feb 27, 2025 7:13 am |
That was why I was wondering whether this was a local network, or across
the internet?. UDP, will usually work fine on a local network, provided there
is not congestion, but across the internet is not reliable at all. If you want to
or must use this, then you have to add your own data recovery protocol to
what you are sending.....
The paint of UDP, is speed over reliability .It is designed for things like
video streaming, where losing a packet just means a hiccup in the video,
but doesn't really 'matter', but being able to guarantee the speed is
important. |
