Hello, I am looking to build a bootloader for a dspic33ck board which has a dedicated FTDI USB chip. It would help to have suggestions of an example loader that could be modified.
Thanks.
Posted: Fri Nov 29, 2024 12:34 pm
Why not just use the CCS bootloader?. Standard serial to the FTDI, so dead
easy.
nazoa
Posted: Fri Nov 29, 2024 4:39 pm
Thanks Ttelmah for the suggestion. I guess it is the ex_bootloader.c in the examples you are suggesting. Is there a host application that tells me how the data is sent to the bootloader? Thanks again
Posted: Sat Nov 30, 2024 1:12 am
Read it.....
The program tells you in the remarks what you ask.
Posted: Mon Dec 02, 2024 8:42 am
for PIC24 and dsPIC chips, you might look at ex_pcd_bootloader.c instead
Posted: Mon Dec 02, 2024 10:47 am
Yes. I must admit I assumed that the PCD bit would be obvious.
