TimC
| Several LED Blinkers including Cylon eye |
Posted: Tue Oct 08, 2024 10:20 pm |
Hi All,
Here is a blink utility that can be useful for:
Testing a new uP, xtal speed tests, fuse config errors, pins incorrectly tied to ground or power and most importantly fun!
To add the Blink utility: | Code: |
#include <led_blink.c>
Blink_Pin(Pin_A1); // Blink for 10 Sec
Up_Seq(Pin_D0, Pin_D7); // test a port
Cylon_Seq(Pin_D0); // Knight Rider
Here is the led_blink.c include source: | Code: |
#ifndef _LED_BLINK_C_
#define _LED_BLINK_C_
// led_blink.c This is a collection of routines for blinking leds
// Starting from the single pin blink to a variable length Cylon Eye
// Details are within each routine.
// Using CCS v5.118 October 8, 2024 v1.0 written by TimC
// This is to match your hardware design.
#ifndef LED_OFF_STATE
#define LED_OFF_STATE 0 // 0=High (V+) will turn leds on.
//#define LED_ON_STATE !LED_OFF_STATE
#endif
#ifndef LED_ON_STATE // only needed for the Cylon blinker
#endif
void Blink_Pin(Int16 Single_Pin,int cycles=20) {
// Led Blink just using a single pin.
// Useful for testing hardware, Testing new uP, xtal speed, debugging,
// Fuse config, i/0 ports, pin tied to ground or Power
// Example:
// #include <led_util.c> // first include this source file
// Blink_Seq(Pin_B5); // later add Blink_seq() with correct pin
// 1/2 sec on, 1/2 sec off makes it easy to determine
// if clock is running a correct speed.
// Cycle count of 20 = 10 seconds for a fast check of osc fuses
// If state of led is +Voltage to turn on then 0, or GND to turn on then 1.
// This is to match your hardware design. So you can set it globally
//#define LED_OFF_STATE 0
int i;
// Return if wildly wrong Start_Pin, End_Pin values
if(Single_Pin < PIN_A0) // error Start_Pin value too low
return;
// LED_OFF_STATE define globally or place 0 or 1 here.
output_bit(Single_pin, LED_OFF_STATE);
if(cycles & 1)
cycles += 1; // bump up cycle counter if odd #
// cycle count of 20 = 10 seconds for a fast check of osc fuses
for(i = 0; i < cycles; i++) {
output_toggle(Single_Pin);
void Ramp_Seq(Int16 Start_Pin, int16 End_Pin, int16 all_led_Pause=1000) {
// Led Ramp going from Start_Pin to the End_Pin.
// Changing all_led_pause to 0 will stop the slow Ramp return back
// to the original led state.
// Useful for checking hardware, Testing new uP, xtal speed, debugging,
// Fuse config, i/0 ports, pins tied to ground or Power
// Example:
// #include <led_util.c> // first include source file
// Ramp_Seq(Pin_A0, Pin_B5,300); // later add Ramp_seq() with correct pins
// This routine could also stress the uP and power supply because it can leave
// many Pins in a ON state. So the current Max is set at 30 Leds
int16 i;
int16 next_led_delay=500; // change as needed
if(Start_Pin < PIN_A0) // error Start_Pin value too low
return;
if(Start_Pin > End_Pin) // Start_Pin must be less then End_Pin
return;
if(End_Pin - Start_Pin > 30) // Prevent a accident with End_Pin way to large
return;
for(i = Start_Pin; i <= End_Pin; i++)
output_bit(i, LED_OFF_STATE);
// Turn on all the Led's one by one till all are on
for(i = Start_Pin; i <= End_Pin; i++) {
output_toggle(i);
delay_ms(next_led_delay);
delay_ms(all_led_Pause);
if (all_led_pause < 20)
next_led_delay=0;
// Now turn Off all the Led's one by one
for(i = End_Pin; i >= Start_Pin; --i) {
output_toggle(i); // restore pin status
void Up_Seq(Int16 Start_Pin, int16 End_Pin, int16 next_led_delay=100) {
// Single Led Blink going from Start_PIN to the End_Pin.
// Example: Up_Seq(Pin_B0, Pin_B7,300);
int16 i;
return;
return;
if(End_Pin - Start_Pin > 80) // Prevent a accident with End_Pin way to large
return;
// Turn on and off all the Led's one by one
output_toggle(i);
output_toggle(i);
delay_ms(next_led_delay*5); // Totally optional pause here
void Up_and_Back_Seq(Int16 Start_Pin, int16 End_Pin, int16 next_led_delay=200) {
// Example: Up_and_Back_Seq(Pin_B0, Pin_B7,300);
// Cylon_seq() is a step up from this routine
int16 i;
return;
return;
return;
//output_high(i);
output_toggle(i);
output_toggle(i);
// Now change direction one by one
for(i = End_Pin-1; i >= Start_Pin; --i) {
output_toggle(i);
void Cylon_Seq(Int16 Start_Pin, int16 Cylon_delay=50) {
// Cylon will look good with as little as 3 Led's
// Example: Cylon_Seq(Pin_D0,100);
// Similar to the Up_and_Back_Seq() but 2 leds go up and back
int16 End_Pin,i,j;
int8 NumofLeds=7; // zero based
int8 repeat=0; // # of cycles, 0=Just do once
End_Pin = Start_Pin+NumofLeds;
for(j = 0; j <= repeat; j++) {
i = Start_Pin;
// Start sequence
output_bit(i, LED_ON_STATE);
delay_ms(Cylon_delay);
output_bit(i+1, LED_ON_STATE);
// across one direction
for(i = Start_Pin; i <= (End_Pin-2); i++) {
output_bit(i+2, LED_ON_STATE);
// ending sequence.
output_bit(i+NumofLeds, LED_OFF_STATE);
output_bit(i+NumofLeds, LED_ON_STATE);
// across return direction
output_bit(i-2, LED_ON_STATE);
// turn off last led and delay before next cycle
output_bit(i+1, LED_OFF_STATE);
#endif // _LED_BLINK_C_ define
