Compiler implements hardware Uart or not?
Torello
PostPosted: Wed Sep 11, 2024 9:54 am     Reply with quote
Is there a simple way to check if the compiler uses the hardware UART for the written code or not? Especially for parts that have a lot of pin select options
Regards, Edwin. PCWHD v5.114
gaugeguy
PostPosted: Wed Sep 11, 2024 1:53 pm     Reply with quote
Look at the C/ASM list file.
Re: Compiler implements hardware Uart or not?
PostPosted: Wed Sep 11, 2024 6:07 pm     Reply with quote
Torello wrote:
If you specify the #use rs232 with a specific UART moniker and also omit / remove any pin assignments, it will use a hardware UART:
#USE RS232 (UART1, BAUD=9600, ERRORS)
If you are using a UART that needs pin assignments and still want to ensure it is hardware you can use #pin_select
#PIN_SELECT U1RX=PIN_B11
#PIN_SELECT U1TX=PIN_B10
lindsay.wilson.88
PostPosted: Thu Sep 12, 2024 9:12 am     Reply with quote
Thanks for raising this point, it was something I was curious about as well. Had a little poke around with a program that just does putc('A');.
With no FORCE_SW specified in the header file, i.e. like this:
it produces the following assembler (comments are mine):
....................    putc('A');
0085:  MOVLW  41      Move 41h (the hex for "A") into W register
0086:  BTFSS  0C.4      Test bit 4 (TXIF) of register 0Ch (PIR1), skip next instruction if set
0087:  GOTO   086      i.e. loop until TXIF=1, i.e. the transmit register can accept data
0088:  MOVWF  19      Move W register (41h) into register 19h (TXREG). This now sends the character.
So that's definitely hardware UART. If FORCE_SW is specified, i.e. like:
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,FORCE_SW)
then it produces:
0048:  MOVLW  41      Move 41h (the hex for "A") into W register
0049:  MOVWF  21      Move W register (41h) into register 21h, a general-purpose register
004A:  CALL   004      Call some subroutine at 004h, this presumably is the software UART thing.
and there's a big bunch of stuff also at 004h, presumably however it bit-bashes the UART.
PostPosted: Thu Sep 12, 2024 11:40 am     Reply with quote
Exactly.
And as you see, easy to do.
There is a code trick that will allow you to detect it as well. When the
hardware UART is used the error byte is a copy of the status register.
This has bit 5 set (to say the receive is enabled), while the software
UART won't have this bit set.
Torello
PostPosted: Wed Sep 18, 2024 6:57 am     Reply with quote
thanx all!
#use delay(internal=8000000)
#PIN_SELECT U1RX=PIN_B7
#PIN_SELECT U1TX=PIN_B6
#use RS232(stream=debug, UART1, Baud=38400, ERRORS)
Works, but doesn't raise a warning. however it not use the internal UART1, I see the Goto xx in the ASM file.
If I put the #use delay() -after- the #use RS232(..) the compiler does throws an error that it needs this declaration.
Isn't that also a good indication? Or does the HW-UART implementation still use delays bases on that declaration?
PostPosted: Wed Sep 18, 2024 7:25 am     Reply with quote
No. Both the UART, and the software UART require the clock setup. How
else do you think they can setup the baud rate?.
What makes you say this doesn't select the UART?. It should. You don't
tell us what chip though, which leaves the possibility the compiler is
not selecting the hardware because these pins can't handle the UART.
PostPosted: Wed Sep 18, 2024 9:53 am     Reply with quote
Torello wrote:
thanx all!
Looks like a hardware UART to me when I look at the ASM:
#case
#include <24fj64ga004.h>
void main(){
  fputc('0', debug);
ASM:
....................   fputc('0', debug);
0242:  MOV.B   #30,W0L
0244:  BTSC.B  223.1
0246:  BRA     244
0248:  MOV.B   W0L,224
024A:  CLR.B   225
0x223 - 0x225 are all HW registers for the chip I put in the example.
PostPosted: Wed Sep 18, 2024 11:45 am     Reply with quote
Exactly. Using 'UART1', forces the compiler to use the hardware. I've never
seen it not do so.
lindsay.wilson.88
PostPosted: Wed Sep 18, 2024 12:00 pm     Reply with quote
So is either using UART1, or specifying the pins (e.g. xmit=PIN_C6,rcv=PIN_C7), both do the same thing?
I'm guessing that specifying the pins is superfluous since you can't pick and choose the pins anyway on most devices?
PostPosted: Wed Sep 18, 2024 1:03 pm     Reply with quote
Specifying pins in the #use also has the potential to make it a software UART. I've had older compiler versions in the past that did that. Best practice for hardware UARTS is to specify the uart (UART1, etc) and not specify the pins
lindsay.wilson.88
PostPosted: Wed Sep 18, 2024 3:26 pm     Reply with quote
That's good to know, thanks!
PostPosted: Thu Sep 19, 2024 1:27 am     Reply with quote
This is why you will see me saying to always use the UARTx syntax. Very Happy
The 'pin' syntax is fine on older chips with the pins fixed in one place. On
later chips that had the pins movable by a fuse, this can easily get confused.
Then when PPS came along it got even easier to confuse it more!....
Set the fuse or PPS to select where the UART is
Then just tell the compiler to use the UART.
The most reliable way to ensure you are using the hardware UART.
