azmi42
18F24K40 RE3 PİN |
Posted: Thu Feb 22, 2024 10:24 am |
I use 18f24k40 in my project. İn dataseheet it refers that RE3 pins just can be as an input. Can i drive PnP transistor with using RE3 Pin? İm trying but cannot do. İ make mclr no on the fuse setting. İs there anyting that i can do _________________ software electronic development |
gaugeguy
Posted: Thu Feb 22, 2024 10:35 am |
Short answer, no.
Do you understand the difference between an input pin and an output pin? |
Joined: 01 Jul 2010 Posts: 9120 Location: Greensville,Ontario
Posted: Fri Feb 23, 2024 6:35 am |
As you need another output pin, simply remap (redefine, change) your I/O pin selection, if you can't then,use the 40 pin version of that PIC,assuming you're using the 28 pinned one.
I've never run out of pins yet. Have used all but 1 though ! I use the 18f46K22 for 99.44% of all my products. |
dyeatman
Posted: Fri Feb 23, 2024 8:14 am |
RE3 is the INPUT ONLY MCLR Pin as default so MCLR would have to be disabled to even use it as an input. _________________ Google and Forum Search are some of your best tools!!!! |
