18F24K40 RE3 PİN
azmi42
18F24K40 RE3 PİN
PostPosted: Thu Feb 22, 2024 10:24 am     Reply with quote
I use 18f24k40 in my project. İn dataseheet it refers that RE3 pins just can be as an input. Can i drive PnP transistor with using RE3 Pin? İm trying but cannot do. İ make mclr no on the fuse setting. İs there anyting that i can do
software electronic development
gaugeguy
PostPosted: Thu Feb 22, 2024 10:35 am     Reply with quote
Short answer, no.
Do you understand the difference between an input pin and an output pin?
PostPosted: Fri Feb 23, 2024 6:35 am     Reply with quote
As you need another output pin, simply remap (redefine, change) your I/O pin selection, if you can't then,use the 40 pin version of that PIC,assuming you're using the 28 pinned one.
I've never run out of pins yet. Have used all but 1 though ! I use the 18f46K22 for 99.44% of all my products.
dyeatman
PostPosted: Fri Feb 23, 2024 8:14 am     Reply with quote
RE3 is the INPUT ONLY MCLR Pin as default so MCLR would have to be disabled to even use it as an input.
Google and Forum Search are some of your best tools
