vas57
18f14k22 DAC |
Posted: Fri Aug 11, 2023 11:36 pm |
I want to make an analog reference for a speed regulator, it's the first time I work with the DAC from 18F14K22, I used the routine below for the test, but I can't find the signal generated by it at the RA0 pin. What is wrong? Thanks for any answer.
#include <18F14K22.h>
#use delay(clock=4M)
int8 i;
setup_dac(DAC_OUTPUT | DAC_VSS_VDD);
for(i=0; i< 128; i++)
dac_write(i);
delay_us(10);
Posted: Sat Aug 12, 2023 1:17 am |
First thing, learn to use the code buttons to post code. I have modified
your posting with these.
Then, how are you detecting this?.
You have read section 21.6 in the data sheet, and looked at the example
figure 21-2?.
You cannot 'drive' anything from this pin, without a buffer....
Ideally you should also turn off the digital input on the pin, otherwise
the PIC can draw extra power (set_analog_pins). The data sheet tells
you this must be done for analog inputs, but it should also be done for
an analog output. |
vas57
Posted: Sat Aug 12, 2023 4:01 am |
Thank you Ttelmah for reply.
I modified the DAC test but I still have no signal on the analog output.
Code: | #include <18F14K22.h>
#use delay(internal = 4MHZ)
#byte VREFCON0 = 0xFBA
#byte VREFCON1 = 0xFBB
VREFCON1 = 0xA8;//VREFCON1 = 0xC8;
VREFCON0 = 0xA0;
set_tris_a( 0xFC );
int8 i=0;
dac_write(i);
delay_us(10);//delay_us(1000);
Posted: Sat Aug 12, 2023 5:32 am |
I repeat:
"Then, how are you detecting this?.
figure 21-2?.
You cannot 'drive' anything from this pin, without a buffer.... "
You can only detect this with a high impedance detector like a scope.
If you have this connected to a load, you will get almost nothing.
Also get rid of your changes. All you want is:
set_analog_pins(PIN_A0);
To tell the chip this is an analog pin.
You have set it as an output pin, so it cannot now work at all, This overrides
any analog use.
You also need to delay after each output, not just once:
dac_write(i);
vas57
Posted: Sat Aug 12, 2023 6:38 am |
Thanks Ttelmah,
I'm using a Hantek DSO4254C oscilloscope, with 1Mohm/20pF probes.
I insert the modification with A0 analog channel and it behaves the same, it does not send a sawtooth signal at the output. |
Posted: Sat Aug 12, 2023 11:09 am |
and you have the delay as shown?. |
Joined: 01 Jul 2010 Posts: 9125 Location: Greensville,Ontario
Posted: Sat Aug 12, 2023 5:35 pm |
curious..
downloaded the datasheet... 20 pin device, seems DAC1OUT pin is RA0 which is ALSO used as PGD ( programming pin ).
If this is correct, have you disconnected your programmer from the PIC ?? |
vas57
Posted: Sat Aug 12, 2023 9:22 pm |
Ttelmah wrote: | and you have the delay as shown?. |
Yes. Now delay is 1000. |
vas57
Posted: Sat Aug 12, 2023 9:23 pm |
temtronic wrote: | curious..
My PICKIT3 sure it is disconnected when I test the program. |
Posted: Sun Aug 13, 2023 1:21 am |
OK. Let's step through a few things:
What compiler version?.
Have you verified the chip is running?. Toggle another pin in the loop,
and verify this works.
The DAC only gives 32 output steps, not 128.
So:
#FUSES NOMCLR, NOWDT, NOLVP
int8 i;
delay_ms(10); //ensure supply is stable before starting
while(TRUE) //using TRUE avoids error message
for(i=0; i< 32; i++)
dac_write(i);
delay_ms(10);
output_toggle(PIN_A1); //check chip is running
You say the programmer is disconnected when testing. Is everything
disconnected from the pin?.
I suspect you have something else wrong. Perhaps the MCLR pin is not
being pulled up when you disconnect your programmer?. I have turned
this off in the above.
This runs on a chip here. |
vas57
Posted: Sun Aug 13, 2023 4:15 am |
Thanks Ttelmah for reply.
CCS Compiler version is 5.066
I run the program under MPLAB v. 8.92 (CCS Compiler) and test it step by step. The program is in the while(1) loop: it does dac_write(i) 32 times(steps), continue with delay_ms(10) once step and then starts from the beginning with 32xdac_write(i),... But on the RA0, pin 19, it does not output anything.
I will also test with an LED on pin A1. |
vas57
Posted: Sun Aug 13, 2023 4:21 am |
My PICKIT3 is totally disconnected when 18f14k22 is running, I remove the cable from the ICSP connector! MCLR is 1 when uC is running. |
vas57
Posted: Sun Aug 13, 2023 4:33 am |
I tested with led: led toggle with 650ms period, so the program is in the while(1) loop. |
Posted: Sun Aug 13, 2023 4:58 am |
curious about this problem...
questions I have .
1) what opamp have you connected to the RA0 pin?
2) dump the listing and confirm that the proper register bits are set (enable and output ) |
vas57
Posted: Sun Aug 13, 2023 5:34 am |
temtronic wrote: |
Thank you temtronic.
I don't use the op-amp as a buffer, I visualize the signal on RA0 with the oscilloscope above. To point 2) I don't know how to answer, what should I do? |
