I am using PIC24FJ512GL406, in one of my project to communicate with a flash chip of winbond over SPI. During the setup of SPI communication using setup_spi function available in device.h file I found there is no parameter for communication speed setup.
Any help regarding that will be very helpful.
Thanks in Advance.
Posted: Mon Jul 17, 2023 6:54 am
Use #USE_SPI, not setup_spi.
setup_spi, is largely deprecated now.
Look also at the top of the forum here in how to use PIN_SELECT. Vital
on modern chips.
However if you must use spi_setup, then the baud goes after the mode
setting. So:
