PIC24F SPI Communication setup
Mrinmoy Dey
PostPosted: Mon Jul 17, 2023 3:35 am     Reply with quote
I am using PIC24FJ512GL406, in one of my project to communicate with a flash chip of winbond over SPI. During the setup of SPI communication using setup_spi function available in device.h file I found there is no parameter for communication speed setup.
Any help regarding that will be very helpful.
Thanks in Advance.
PostPosted: Mon Jul 17, 2023 6:54 am     Reply with quote
Use #USE_SPI, not setup_spi.
setup_spi, is largely deprecated now.
Look also at the top of the forum here in how to use PIN_SELECT. Vital
on modern chips.
However if you must use spi_setup, then the baud goes after the mode
setting. So:
#PIN_SELECT SCK1OUT=PIN_B0
#PIN_SELECT SDO1=PIN_B1
#PIN_SELECT SDI1=PIN_B2
   setup_spi(SPI_MASTER | SPI_SCK_IDLE_LOW | SPI_XMIT_L_TO_H | SPI_SAMPLE_AT_MIDDLE, 400000);
   //setup for 400Kbps
Obviously with suitable settings for your SPI.
