nailuy
| printf int32 |
Posted: Tue Feb 21, 2023 5:38 pm |
how to print long long (double) or int32?
| Code: | int32 test = 16777215
printf("%Lu", test); |
resoult is 65535.
how to print value larger than 65535?
not help %9Lu
and
is not working %LLu |
Posted: Wed Feb 22, 2023 2:22 am |
What compiler version do you have?.
%Lu should print this fine, provided the value genuinely is an int32.
Some of the very early V4 compilers had problems with int32 (about 4.119
I think). |
nailuy
Posted: Wed Feb 22, 2023 3:37 pm |
| my version is 5.101 |
Posted: Thu Feb 23, 2023 2:55 am |
I've just built a test with 5.101, and a PIC18F2420.
Merrily works:
#include <18F2420.h>
#device ADC=10
#FUSES NOWDT
#use delay(crystal=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
int32 test = 16777215;
setup_adc_ports(NO_ANALOGS, VSS_VDD);
delay_cycles(1);
Outputs to the terminal : 16777215
This on a basic MicroChip prototype board (20MHz crystal). |
