Joined: 01 Jul 2010 Posts: 9500 Location: Greensville,Ontario
Posted: Mon Jan 09, 2023 9:57 am |
You should post your complete program,so we can see it, and others can cut/paste/compile/test on their bench.
You need to be real careful about 'FUSES', do NOT assume if you don't edit them, that they WILL work for you ! Some 'default' option may not be what you want.
When I started using the PIC18F46K22, I created a '46k22fuses.h' file that has every fuse listed, one per line, with comment at the end. If a project needs a configuration other than the basic 'working' version, I copy the original, make changes, and save with a filename that has the project embedded in it.
This does 2 things for me.
1) the fuses file has EVERY fuse in it,so I can see what they are...
2) since the fuse file is now a #include, it makes 'main()' easier to read. |
Posted: Mon Jan 09, 2023 10:10 am |
On your pin not toggling at higher speed, it depends totally on what is
attached. Using 'output_toggle' has the problem that this works by
reading the pin level, inverting this, and writing this back to the pin.
Now if the pin is attached to something capacitive, it may well not
change to the level specified in 2uSec. Result the toggle stops working.
Having brownout enabled, should make the chip physically reset for 90%
of supply droop problems. However won't affect things like noise spike
problems. Realistically, you are going to have to debug what part of the
code actually hangs. Could be something waiting for an external event, or
a supply spike, etc. etc.. |
MCUprogrammer
Posted: Mon Jan 09, 2023 10:11 am |
Most of the problems have been fixed in the dsPIC30F3014.
#use delay(clock=100MHz,crystal=25MHz)
Now there is another problem. I increased it to 100mhz with 25MHZ crystal in the attached program. I'm toggle with PIN_C13. Output is always at 0, no pulse.
#use delay(internal=120MHz)
When I write the code above, the same problem still persists.
When I just connect a 25MHZ crystal and create a 1ms interrupt, there is a nice pulse. Could the problem be with the compiler? _________________ Best Regards...
MCUprogrammer
_______________________________
Work Hard |
Posted: Mon Jan 09, 2023 11:37 am |
I don't have time to download this particular PIC's data sheet, but one thing that has bitten me in the past is slew rate control, which by default is usually on. That is enough to completely suppress any high speed things you want to do, like toggling a PIN every few us. |
MCUprogrammer
Posted: Mon Jan 09, 2023 1:45 pm |
@Ttelmah the code below didn't work.
#use delay(clock=100MHz,crystal=25MHz) _________________ Best Regards...
MCUprogrammer
Work Hard |
MCUprogrammer
Posted: Mon Jan 09, 2023 2:23 pm |
@temtronic can you share this 46k22fuses document _________________ Best Regards...
MCUprogrammer
Work Hard |
Posted: Mon Jan 09, 2023 11:20 pm |
MCUprogrammer wrote: | @Ttelmah the code below didn't work.
#use delay(clock=100MHz,crystal=25MHz) |
Yes it does. I tested that last night and it merrily runs on my chip.
Are you sure your hardware really is working properly?
One thought, you have got the -30 release version of the chip?. You do
realise the standard chip will only clock to 80MHz. |
Posted: Tue Jan 10, 2023 3:23 am |
newguy wrote: | I don't have time to download this particular PIC's data sheet, but one thing that has bitten me in the past is slew rate control, which by default is usually on. That is enough to completely suppress any high speed things you want to do, like toggling a PIN every few us. |
The 3014, doesn't have slew rate control, except on the I2C.
I thought of that, and went back and looked at my code.
I'm strongly suspicious there may be a hardware problem. There needs to
be four ground and supply connections on that chip. Each must have a
separate decoupling capacitor. My board has 3*0.1uF ceramic right by
the pins, and also a 10uF ceramic by the fourth pair. The supply also
needs to be able to deliver in PIC terms massive currents. The chip can
draw up to 250mA, and momentarily way beyond this (on some signal
changes I've seen nSec spikes of nearly an amp!). |
MCUprogrammer
Posted: Tue Jan 10, 2023 4:34 am |
I tried but it didn't work. But the code below worked.
#use delay(clock=66.67MHz,crystal=25MHz) this works.
Also, typing #use delay(internal=120MHz) doesn't work.
I'm doing #fuses NOMCLR of the dsPIC33EV256GM104 processor, it doesn't work. What will I do for this? _________________ Best Regards...
MCUprogrammer
Work Hard |
Posted: Tue Jan 10, 2023 7:05 am |
hmm, since it works at 66MHZ and not faster, it sounds like you have the 80MHz version.
this would be called 'overclocking' in the PC world. |
Posted: Tue Jan 10, 2023 7:59 am |
The 33EV, has the 'proper' programmable PLL that most of the PIC24's,
and PIC33's have. The 3014 does not have this. It allows you to have
pretty much any clock.
The setting for this is just done by the clock statement. It is not does as
a fuse on this chip. The oscillator is programmed _after_ the chip starts.
Big difference here though is that unlike the 3014, the clock only runs
at 2*Fcy, rather than the 4*Fcy of the 3014. So (for example), with
a 24Mhz crystal:
#use delay(crystal=24MHz, clock=140MHz)
gives you 70MIPS operation (actually gives fosc/3 to PLL - *35 to
give 280MHz, then /2 to give 140MHz).
Any fuses you need, will depend on what you actually want to do. So
for example if using the I2C, you may need the ALTI2C fuse etc..
I'm still worried that his original problem may be decoupling. On the
3014, you need four decoupling capacitors, and all four PSU connections
made. My board had decoupling just a few mm from each pair of
supply pins, and these are fed from power planes inside the board. These
chips are 100* more fussy than smaller PIC's on their supply and
decoupling.
On the 104, you have three sets of supply pins, and the Vcap connection.
The capacitor on this needs to be a low ESR type. I use 10uF ceramic
capacitors for the Vcap. These should be connected with quite thick traces
and only a few mm from the leg. |
MCUprogrammer
Posted: Wed Jan 11, 2023 6:25 am |
The fix for that is to have an INT_OSCFAIL handler, that simply tests
the clock failure status bit (OSCCON:3), and if it is clear return immediately.
It does tell you this in the errata sheet, |
MCUprogrammer
Posted: Wed Jan 11, 2023 7:24 am |
yes i know. I installed the #INT_OSCFAIL interuppt accordingly. This solves the problem. but there is one more thing i don't understand.
I pulled up with MCLR 10K. It has a reset button next to it.
When I turn on the processor for the first time, the processor seems to do nothing. Turning it on and off a few times fixes the problem. What should I do for this? _________________ Best Regards...
MCUprogrammer
Work Hard |
Posted: Wed Jan 11, 2023 7:58 am |
That almost certainly implies your power supply does not meet the
specified rise time. This is a common problem with the DsPIC's, where
supplies that worked fine for the PIC16/18's, won't reliably start these
more powerful chips. If you check the data sheet, I think it requires a
rise time to 5v that is less than 0.1sec. If you go over this the internal
reset circuit won't work properly.
Two solutions:
1) improve the rise time of the supply.
2) add an external reset circuit to operate MCLR. |
