Laser level receiver project?
Goto page Previous  1, 2, 3, 4
Sam_40
PostPosted: Fri Jan 06, 2023 12:28 pm     Reply with quote
Ok, I do see the laser beam with the processor through the inputs. I just need to figure out how to only give valid outputs when it sees the pulses at one per 100mS or 10 per second (10Hz). I will try to get the code right.
Thank you
PostPosted: Sat Jan 07, 2023 7:42 am     Reply with quote
since the 'rotational speed' of the laser is slow..
maybe this post...
https://www.ccsinfo.com/forum/viewtopic.php?t=54909
could be useful ?
You know the 'high' is about 280us, 'low' is 100ms-280us.
You'll have to figure out the 'math' ,based on PIC clock speed, which CCP used, etc.
The 'pulse is 'high' variable' should be within a few counts and represent 280us.
it will vary of course, unlikely the LASER has feedback to maintain a constant speed of say 10.423 RPM.
If it goes to zero then you've lost the beam.
Page 4 of 4
