Cómo leer un pic
Miguel77
Cómo leer un pic
PostPosted: Sat Oct 01, 2022 8:07 pm     Reply with quote
Hola a todos como puedo leer un pic24fg64 con el pickit3
Lo intento pero no me deja leerlo,si puedo borrar el pic
Gracias
dyeatman
Translation
PostPosted: Sat Oct 01, 2022 9:06 pm     Reply with quote
Hello everyone, how can I read a pic24fg64 with pickit3
I try but it won't let me read it, if I can delete the pic
Google and Forum Search are some of your best tools
Humberto
PostPosted: Mon Oct 03, 2022 10:54 am     Reply with quote
Is it an original Pickit3? If it's a clone, it's likely that some microcontrollers don't recognize them.
If you are not using ICSP port, try this suggestions:
1) Make sure the Pickit3 voltage setting is correct for that processor.
2) Check the jumper settings of the base where the ZIF socket is located
3) Update Pickit3 firmware
Saludos
Humber
PostPosted: Mon Oct 03, 2022 11:00 am     Reply with quote
Big question is what software he is using?.
The stand alone program with the Pickit3, only supports the same chips as
the Pickit2. Many more are added when you use MPLAB-X.
If using this, then look at it's list of supported devices.
It'd also help if he gave us the proper part number. FG64, does not exist.
Possibly FJ?. Then to actually know if it is supported the rest of the number
is also needed. So something like PIC24FJ64GA004.
If so, this is supported in the MPLAB-X IPE (a horrid program, Microchip
seem determined to make every new program much worse than it's previous
version), but it does work....
E_Blue
PostPosted: Thu Oct 06, 2022 11:34 am     Reply with quote
Also took out some features that the old MPLAB IDE has, that's why I keep using MPLAB IDE as much as I can.
For debugging is way more useful the old MPLAB, you can save and load a register from an external file, on the new, "more advanced" MPLAB X that's not possible, only can change registers manually and in Hexadecimal format only. Really annoying!
Electric Blue
PrinceNai
PostPosted: Fri Oct 07, 2022 8:43 am     Reply with quote
Code protection?
