rudy
| SIM 808 GPS INFO - RETRIEVING DATA |
Posted: Tue Jun 07, 2022 12:55 pm |
Hi there,
I am working with a SM808 GSM and GPS module, and I pick latitude and longitude data in the RS232 buffer, these values need to be converted from degrees and decimal minutes to decimal degrees, so, I take out the degrees and mount the decimals in other to divide them by 60 and obtain the desired result. I have to do this twice, once for the latitude and another for longitude. I ask if there is another “smarter” way to do that!
In this example, the latitude is = 25.41169, so I pick 25 and mount 24701446. The 24701446 divides by 60 = 41169, resulting in 25.41169.
void GET_GPS()
printf("AT+CGPSINF=0\r\n");
LATITUDE[0]=25; //((GSM_BFR[0X0E]-48)*10)+((GSM_BFR[0X0F])-48);
LATITUDE[1]=24; //((GSM_BFR[0X10]-48)*10)+((GSM_BFR[0X11])-48);
LATITUDE[2]=70; //((GSM_BFR[0X13]-48)*10)+((GSM_BFR[0X14])-48);
LATITUDE[3]=14; //((GSM_BFR[0X15]-48)*10)+((GSM_BFR[0X16])-48);
LATITUDE[4]=46; //((GSM_BFR[0X17]-48)*10)+((GSM_BFR[0X18])-48);
LTE=(float)LATITUDE[1]*1000000+(float)LATITUDE[2]*10000+(float)LATITUDE[3]*100+(float)LATITUDE[4];
LTE=LTE/60;
Regards; |
Joined: 01 Jul 2010 Posts: 9596 Location: Greensville,Ontario
Posted: Tue Jun 07, 2022 2:14 pm |
| Never worked with them, but... can you reprogram the GPS to send you the data (Lat and LONG) in the format YOU want ?? |
rudy
Posted: Tue Jun 07, 2022 2:16 pm |
Unfortunately no! The only think I got from it is the speed in KM/h, because the default unit is knots.
The standard units format from all SIM line is DDmm.mmm.
Regards! |
PrinceNai
Posted: Tue Jun 07, 2022 6:05 pm |
| Quote: |
What are you trying to to convert? What does "mount" mean? No disrespect, just asking. Where did those 24701446 came from? What was the string from GPS and how should the result look like? In your example the end result is the same as the input. |
Posted: Wed Jun 08, 2022 1:54 am |
One tiny thing.
It is generally faster and smaller to multiply rather than divide. So the code
for val=source/60, will be larger and slower, than val=source*0.01666666.
Might be worth declaring a define for this, perhaps 'OVER60", and trying
multiplying instead of dividing. It may well save some space and time.
#define OVER60 (0.01666667)
val=source*OVER60;
Now the saving is greatest on the more basic PIC's (16,18), which don't
have a hardware divide instruction, and almost disappears on the DsPIC's.
On the PIC18, the multiplication is about 4* faster than the division.
On a basic test the multiplication code is 100 bytes smaller on a PIC18. |
Posted: Wed Jun 08, 2022 4:43 am |
| Hmm, any chance he could use 'integer math' instead of the 'nasty' floating point ? If so, it should be a LOT faster....... |
rudy
Posted: Wed Jun 08, 2022 5:31 am |
Hum.... That's fine for me. In fact, I always try the best and shortest ways to do the job. The processor is 18F2550, and it is running very well, but I do really get suspicious when I fell that I am not doing the best way it can....
| Ttelmah wrote: | One tiny thing.
val=source*OVER60;
rudy
Posted: Wed Jun 08, 2022 5:34 am |
That's a good point temtronic, but I don't know how to do it. I tried with int32 variable, but it seem to not work well, really don't know why.
I love to test if you help me....Using float because in debugger, it works very well.
| temtronic wrote: | | hmm, any chance he could use 'integer math' instead of the 'nasty' floating point ? If so ,it should be a LOT faster....... |
rudy
Posted: Wed Jun 08, 2022 7:30 am |
It worked flawless with int32... I think it is ok now! Besides it could be much more easily if the GPS send already in decimals degrees, it is ok. Now start decoding the speed, but this shall be easier because the units is km/h with the sentence "AT+CGPSINF=64\r\n".
Thank you all!
| Code: | void GET_GPS()
GSM_LCK=1;
int i;
LATITUDE[0]=((GSM_BFR[0X0E]-48)*10)+((GSM_BFR[0X0F])-48);
LATITUDE[1]=((GSM_BFR[0X10]-48)*10)+((GSM_BFR[0X11])-48);
LATITUDE[2]=((GSM_BFR[0X13]-48)*10)+((GSM_BFR[0X14])-48);
LATITUDE[3]=((GSM_BFR[0X15]-48)*10)+((GSM_BFR[0X16])-48);
LATITUDE[4]=((GSM_BFR[0X17]-48)*10)+((GSM_BFR[0X18])-48);
LONGITUDE[0]=((GSM_BFR[0X1A]-48)*10)+((GSM_BFR[0X1B])-48);
LONGITUDE[1]=((GSM_BFR[0X1C]-48)*10)+((GSM_BFR[0X1D])-48);
LONGITUDE[2]=((GSM_BFR[0X1F]-48)*10)+((GSM_BFR[0X20])-48);
LONGITUDE[3]=((GSM_BFR[0X21]-48)*10)+((GSM_BFR[0X22])-48);
LONGITUDE[4]=((GSM_BFR[0X23]-48)*10)+((GSM_BFR[0X24])-48);
LTE=(int32)LATITUDE[1]*1000000+(int32)LATITUDE[2]*10000+(int32)LATITUDE[3]*100+(int32)LATITUDE[4];
LTE=LTE/60;
sprintf(GSM_BFR, "<%lu>", LTE);
LATITUDE[1]=((GSM_BFR[1]-48)*10)+(GSM_BFR[2]-48);
LATITUDE[2]=((GSM_BFR[3]-48)*10)+(GSM_BFR[4]-48);
LATITUDE[3]=((GSM_BFR[5]-48)*10)+(GSM_BFR[6]-48);
LATITUDE[4]=0X00;
LTE=(int32)LONGITUDE[1]*1000000+(int32)LONGITUDE[2]*10000+(int32)LONGITUDE[3]*100+(int32)LONGITUDE[4];
LTE=LTE/60;
LONGITUDE[1]=((GSM_BFR[1]-48)*10)+(GSM_BFR[2]-48);
LONGITUDE[2]=((GSM_BFR[3]-48)*10)+(GSM_BFR[4]-48);
LONGITUDE[3]=((GSM_BFR[5]-48)*10)+(GSM_BFR[6]-48);
LONGITUDE[4]=0X00;
//SPEED IN KM/H
// printf("AT+CGPSINF=64\r\n");
// +CGPSINF: 64,94.66,T,,M,0.000,N,0.000,K,A
BFR_CNT=0;
GSM_LCK=0;
GSM_GET_GPS=0;
