18F46K22 EXTERNAL INT [Solved]
rudy
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu May 26, 2022 8:07 am     Reply with quote
Hi there.
Do I need to do any other thing when I use external int 0 on this chip? Because I feed the RB0 with 1Hz pulse, it seems that the ISR ignores the low state of the pulse.
   SETUP_ADC_PORTS(NO_ANALOGS);
    SETUP_COMPARATOR(NC_NC_NC_NC);
      SETUP_COUNTERS(RTCC_INTERNAL,RTCC_DIV_16);
   SETUP_TIMER_1(T1_DISABLED|T1_DIV_BY_1);
      SETUP_TIMER_2(T2_DISABLED,0xFF,16);
      SETUP_TIMER_3(T3_DISABLED|T3_DIV_BY_8);
      SETUP_TIMER_4(T4_DISABLED,0xFF,16);
      SETUP_TIMER_5(T5_DISABLED|T5_DIV_BY_8);
      SETUP_TIMER_6(T6_DISABLED,0xFF,16);
   SET_TRIS_A(0b00000000);
   SET_TRIS_B(0b11100001);
   SET_TRIS_C(0b11111111);
   SET_TRIS_D(0b11111111);
   SET_TRIS_E(0b11111111);
   PORT_B_PULLUPS(FALSE);
   EXT_INT_EDGE(0, L_TO_H);
   SETUP_CCP1(CCP_CAPTURE_RE);
   ENABLE_INTERRUPTS(INT_EXT);   //ENABLE RTC INTERRUPTS
//   ENABLE_INTERRUPTS(INT_CCP1); //INABLE INFRARED INTERRUPTION
   ENABLE_INTERRUPTS(GLOBAL); //ENABLE GLOBAL INTERRUPTS
#INT_EXT   //RTC SR
void RB0_ISR(void)
   SEGUNDOS++;
   if(SEGUNDOS>=60)
      SEGUNDOS=0;
      MINUTOS++;
   if(MINUTOS==60)
      MINUTOS=0;
      HORAS++;
   if(HORAS==24)HORAS=0;
   CLK=1;
When bit CLK is set, I do some other things on the program, but, somehow, it seems to be always been set on the ISR.
Taking a look at datasheet, I saw that RB0 is also used on SR LATCH and ECCP, but I cannot see any relation to these functions.
Regards;
PostPosted: Thu May 26, 2022 10:17 am     Reply with quote
What is the Vdd voltage of your PIC ?
What are the voltage levels (high and low) of the 1 Hz pulse ?
If your PIC is running at 5.0v, the 1 Hz pulse needs to be at
least 4.0v for the high level. Ideally it should be higher.
The low voltage level should be a max of 0.8v and ideally lower.
PostPosted: Thu May 26, 2022 10:53 am     Reply with quote
Er. Not sure what you mean, but it will 'ignore the low state'. The
interrupt will trigger when the signal goes high....
rudy
PostPosted: Thu May 26, 2022 11:29 am     Reply with quote
Weird!!!!
I may did some mistake. Suddenly, the problem vanishes....
The 1HZ is 0-5V.
It is OK now, working fine.
Regards!
PostPosted: Thu May 26, 2022 11:41 am     Reply with quote
In your original posted code, show above, you have it set to trigger on
the rising edge. When it goes from low to high, it will trigger.
It's doing exactly what you told it to do above.
rudy
PostPosted: Thu May 26, 2022 11:46 am     Reply with quote
No issues..
There is an BC-548 transistor driving the signal before it enter on RB0, the +5V was loose on the collector, and that's was the problem.
I sorry to disturb.. Once that this thread don't help much, please delete it from the forum.
I apologize the mistake.
Regards,
