DSPIC33EP512GP502 -- PCD v5.115 compiler ram issue
Marco27293
PostPosted: Tue Jul 18, 2023 10:17 am     Reply with quote
I'm using a DSPIC33EP512GP502 (48K RAM) with PCD v5.115 compiler.
If I define :
char arr[28000]={};
I get:
Memory usage: ROM=0% RAM=57% - 57%
Else if I define:
char arr[30000]={};
I get:
Error#74 Not enough RAM for all variables
How is it possible?
If I define two distinct array (size first 28000, size second 10000) all is fine...
What is the problem?
Regards
PostPosted: Wed Jul 19, 2023 1:23 am     Reply with quote
Problem is that the RAM is not just a large unused lump of continuous
memory. There are other things that sit 'in' it. One is the stack. This sits
just below 0x7FFF (so with the default stack 0x7F80 - 7FFF.).
Your array when it goes over 0x7f7F-0x1000 (the user RAM starts here)
can't fit without being broken into two. So about 28500 bytes. If your
stack is bigger, earlier than this.
You can explicitly locate the stack closer to the end of memory, using
the #BUILD command. So:
#build (stack=0xB000:0xB1FF)
Will put the stack up at 0xB000, and you will then find your array will
work. This gives a 512byte stack.
