Posted: Tue May 10, 2022 6:49 am |
You still have the problem that your timer will not remain synchronised to
your external loop.
As a comment try to indent your code to help readability.
Do the work inside the interrupt. Don't change channels outside. Now you
seem to be trying to interrupt about 20* per second, and do about one
second each for CO and NTC. I've done it so the entire cycle is one
second. Something like:
//Have a global int1 done_flag=FALSE;
void timer0_test()
set_timer0(60);
switch (sayi++) {
case 0:
set_adc_channel(4);
sum_NTC=0;
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
sum_NTC+=read_adc();
break; //sum 8 readings
case 9:
avg_NTC=sum_ntc/8;
case 10:
set_adc_channel(7);
sum_CO=0;
case 11:
case 12:
case 13:
case 14:
case 15:
case 16:
case 17:
case 18:
sum_CO+=read_adc()
case 19:
avg_CO=sum_CO/8;
sayi=0;
done_flag=TRUE;
Depending on the age of your compiler you may get a warning about
switch statements without breaks. Either just ignore this or use the
'nobreak' fix in the compiler's 'readme'.
Then in your main:
//Then have a main like:
setup_timer_1(T1_DISABLED);
set_tris_c(0b00001111);
set_tris_a(0x00);
output_a(0x00); //red led
output_c(0x00);
setup_adc(adc_clock_div_8);
setup_adc_ports(sAN4 |sAN7, VSS_VDD );
setup_timer_0(T0_INTERNAL | T0_DIV_256);
set_timer0(60);
while (true)
//wait for the timer to do a set of samples
while (done_flag==FALSE)
done_flag=FALSE;
//==================red lED================
if (( avg_CO > 0) || ( avg_CO < 240) )
output_low(pin_a5);
else if (avg_CO > 245)
output_high(pin_a5);
//==================green LED ==============
output_toggle(pin_a4);
//==================Stein Hart for NTC ==========
R2 = R1 * (1023.0 / (float)avg_NTC - 1.0);
logR2 = log(R2);
T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
T = T - 273.15;
//================== printf =================
printf ("Temperature:%f ",T);
printf("AVG_CO-ADC= %lu ",avg_CO);
Delfinss
TİMER0 and ADC with 16F1509 |
Posted: Fri May 13, 2022 5:06 am |
Hi again
Unfortunately this is the result
Temperature:-51.26 AVG CO-ADC= 1
Please share your suggestions. I also try a lot before writing to the forum, but I have not been successful yet.
Quote: | //Have a global int1 done_flag=FALSE;
void timer0_test()
set_timer0(60);
switch (sayi++) {
case 0:
set_adc_channel(4);
sum_NTC=0;
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
avg_NTC=sum_ntc/8;
case 10:
set_adc_channel(7);
sum_CO=0;
case 11:
case 12:
case 13:
case 14:
case 15:
case 16:
case 17:
case 18:
sum_CO+=read_adc()
case 19:
avg_CO=sum_CO/8;
sayi=0;
done_flag=TRUE;
set_tris_a(0x00);
output_c(0x00);
set_timer0(60);
while (true)
done_flag=FALSE;
output_low(pin_a5);
logR2 = log(R2);
T = T - 273.15;
Joined: 01 Jul 2010 Posts: 8511 Location: Greensville,Ontario
Posted: Fri May 13, 2022 5:41 am |
you need to show us your current code,
this...
AVG CO-ADC= 1
could be the result was 0 or 1... OR defined as a short OR some 'weird math'.
also when doing 'math', you should printout intermediate results of complicated calculations and compare to YOU doing the math with pencil and paper. having brackets in the wrong spot can cause all sorts of 'funny' numbers....
it's impossible to KNOW what's happening until we SEE your code. |
Delfinss
Posted: Fri May 13, 2022 8:42 am |
I think it worked
I was able to get values with fast_io and not standard_io
Will this cause any problems for me?
Temperature:26.09 AVG_CO-ADC= 208
Temperature:26.18 AVG_CO-ADC= 207
thank you everyone. |
Posted: Fri May 13, 2022 11:33 am |
That's because of the position of the two lines shown in bold.
In Standard I/O mode, they will over-write the TRIS settings of the
previous two lines.
If you want the program to work with Standard I/O, you need to
move the two lines in bold so they are above the set_tris lines.
set_tris_a(0x00);
output_c(0x00);
Posted: Fri May 13, 2022 4:04 pm |
I've only needed fast-IO() 2-3 times in 25 years...
Save yourself a LOT of headaches, and just use standard_io ( the default).
If, IF, you really, really speed, then and ONLY then use fast-io.
Posted: Sat May 14, 2022 7:18 am |
and the key point as PCM points out is 'position'. To use standard_io,
change the order of the commands to:
output_c(0x00);
set_tris_a(0x00);
The point is that with a port wide output, using standard I/O, this includes
inside the command setting the tris on the whole port to output.
So set the TRIS after this, not before. |
Delfinss
Posted: Wed May 18, 2022 8:58 am |
thank you all very much, you did a great job |
