GENERATING PWM USING THE TIMER
akin54
PostPosted: Fri Mar 04, 2022 12:27 am     Reply with quote
Hello everyone.
I want to generate pwm from this processor (PIC12F683) without using the ccp1 leg. I want to use the GP5(A5) pin for this operation. The electronic card circuit I have drawn does not allow other conditions. When I try to generate pwm with interrupt using timer, the while loop of my program starts to crash. While I am creating a continuous pwm signal, I want to operate comfortably in my while loop. I would be glad if you help. Thanks in advance.
#include <12F683.h>
#device ADC=10
#use delay(internal=8000000)
#include <main.h>
#FUSES NOMCLR                                         //MCLR = A3 pin
   setup_adc_ports(sAN2, VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_2);
   port_a_pullups(0x0A);
   set_tris_a(0x0E);
   output_a(0x00);
      if(input(pin_a3)==0)
         output_high(pin_a1);
         output_low(pin_a1);
@electsoftware
PostPosted: Fri Mar 04, 2022 1:08 am     Reply with quote
Post your code for the timer interrupt. Post the code in main() that
enables it, and post the interrupt routine. You left that code out of
your posted program.
Here, you think a weak pullup is enabled on pins A1 and A3.
But pin A3 doesn't have that ability. Look at this diagram on page 36:
REGISTER 4-4: WPU: WEAK PULL-UP REGISTER
It shows no pullup is available on pin A3 when using the NOMCLR fuse.
12F683 data sheet:
https://ww1.microchip.com/downloads/en/DeviceDoc/41211D_.pdf
output_a(0x00);
This line sets all pins as outputs, unless you have a secret
#use fast_io(a) statement that you didn't post.
akin54
PostPosted: Fri Mar 04, 2022 1:49 am     Reply with quote
#include <main.h>
#int_timer2
void timer2 ()
output_high(pin_a5);
delay_us(12);
output_low(pin_a5);
   setup_timer_2(T2_DIV_BY_1,1,1);
   port_a_pullups(0x02);
   set_tris_a(0x0E);
   output_a(0x0E);
   enable_interrupts(INT_timer2) ;
         output_high(pin_a0);
         output_low(pin_a0);
@electsoftware
akin54
PostPosted: Fri Mar 04, 2022 1:50 am     Reply with quote
Yes, now I see. I made the MCLR pin a hardware button.
@electsoftware
