Pic to pic UART data Transfer
Goto page Previous  1, 2
PostPosted: Tue Mar 01, 2022 7:18 am     Reply with quote
Combining nibbles into bytes is easy:
   int8 A;
   int8 B;
   int8 combined;
   A=something;
   B=something_else;
   combined = (A*0xF) &((B &0xF) << 4);
   //Then to extract values
   A=combined & 0xF;
   B=(combined>>4) & 0xF;
As written, this combines two numbers and extracts these back, also making
sure any 'extra' bits are thrown away.
gaugeguy
PostPosted: Tue Mar 01, 2022 9:02 am     Reply with quote
Shouldn't that be :
combined = (A*0xF) | ((B &0xF) << 4);
It seems that 0x0F & 0xF0 would result in 0 but I might be missing something.
PostPosted: Tue Mar 01, 2022 11:30 am     Reply with quote
No. It should be:
combined = (A & 0xF) | ((B & 0xF) << 4);
Two typing errors, you only spotted one....
A & 0xF gives the low 4 bits of A.
Then B & 0F gives the low 4 bits of B
These are then rotated left 4 times.
On the PIC 16 & 18, you can actually use:
combined = (A&0xF) | swap(B &0xF);
This uses the internal swap instruction that swaps the high and low
nibbles in a single instruction, while the rotation takes four instructions.
This doesn't exist on the DsPIC's.
CaptainOnedin
PostPosted: Wed Mar 02, 2022 1:05 am     Reply with quote
Thanks alot you guys all!
Finally i figured out it. There is only one thing waiting to solve. Why IOC doesn't trigger with UART signal? I'll try all pins for it when i free.
I'm grateful to you guys.
Page 2 of 2
