Separate
Robert Stogen
Separate
PostPosted: Sun Jun 29, 2003 1:30 pm     Reply with quote
How do I use "separate" for functions without get"Procedure definition different from previous definition"?
I have tried everything I can think of.
I can use separate before main and it compiles but any other
function after main I get this error msg. I even made a dummy
function that does nothing and I still get this error.
Original Post ID: 144515635
Douglas Kennedy
Re: Separate
PostPosted: Sun Jun 29, 2003 2:34 pm     Reply with quote
<font face="Courier New" size=-1>:=How do I use "separate" for functions without get"Procedure definition different from previous definition"?
:=I have tried everything I can think of.
:=I can use separate before main and it compiles but any other
:=function after main I get this error msg. I even made a dummy
:=function that does nothing and I still get this error.
I assume you are forward declaring your routines...if so #separate needs to be in front of the forward declaration as well as the actual routine.</font>
Original Post ID: 144515636
RS
Re: Separate
PostPosted: Mon Jun 30, 2003 6:02 am     Reply with quote
:=:=How do I use "separate" for functions without get"Procedure definition different from previous definition"?
:=:=I have tried everything I can think of.
:=:=I can use separate before main and it compiles but any other
:=:=function after main I get this error msg. I even made a dummy
:=:=function that does nothing and I still get this error.
:=I assume you are forward delaring your routines...if so #seperate needs to be in front of the forward declaration as well as the actual routine.
Now I am!! Thanks Douglas.
Original Post ID: 144515642
