Khansokhua
| PIC16F877A int_timer1 |
Posted: Mon Nov 29, 2021 4:36 pm |
| Code: | #include <Timerlar.h>
#fuses XT
#use delay(clock=4M)
int i=0;
int j=0;
const int segment[16]= {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7C,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
#int_timer1
void timer_say()
set_timer1(63036);
if(i==50)
i=0;
output_c(segment[j]);
j++;
if(j==16)
j=0;
i++;
set_timer1(63036);
output_a(0x02);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
enable_interrupts(int_timer1);
Hi
I measured 0.020032s the overflow time but I calculated for exact value 0.02 s. Which point I have been missing? I wonder why showed up this ? Respects |
gaugeguy
Posted: Mon Nov 29, 2021 4:59 pm |
| Did you account for the time it takes from when the interrupt is triggered until you execute your set_timer1 command? |
Khansokhua
Posted: Tue Nov 30, 2021 3:26 am |
| Actually, I measured set_timer1's value "4" before it's been set "63036" |
mdemuth
Joined: 16 Apr 2007 Posts: 71 Location: Stuttgart, Germany
Posted: Tue Nov 30, 2021 4:01 am |
Take a look into the ASM file (lst). It takes a few cycles to save registers before set_timer is executed.
(I also would recommend to change the "overflow-counters" if (x==yy) into if (y>=yy) for best practise..) |
Posted: Tue Nov 30, 2021 5:53 am |
Remove the line shown in bold below:
| Quote: |
void timer_say()
set_timer1(63036);
if(i==50)
i=0;
j++;
if(j==16)
j=0;
i++;
Replace the line in bold with this line:
| Code: | set_timer1(PRELOAD + get_timer1());
Put this line above the #int_timer1 line:
| Code: | | #define PRELOAD 63036 |
