aldina
PIC16f526 PIN C5 output |
Posted: Wed Sep 15, 2021 2:12 am |
Hello all,
I can't use PIN C5 of PIC16f526 as output. I've fixed this pin as output port but when I use OUTPUT_HIGH(PIN_C5) nothing happen.
##include <16F526.h>
#device ADC=8
#fuses INTRC,WDT,MCLR,PROTECT
#use delay(clock=8000000)
#use fixed_io (c_outputs = pin_c5)
#use fixed_io (b_outputs = pin_b5)
int8 RH_Signal, LH_Signal;
setup_adc_ports(PIN_B0);
setup_adc_ports(PIN_B1);
setup_adc(ADC_CLOCK_DIV_16);
output_low(PIN_B5); //sector Lateral Direito
output_low(PIN_C5); //sector Lateral Esquerdo
while (true)
restart_wdt();
RH_Signal = 0;
LH_Signal = 0;
RH_Signal = Right();
LH_Signal = Left();
if(RH_Signal >= 50 && LH_Signal >= 50)
if(input(PIN_B2) == 1 || input(PIN_C0) == 1)
OUTPUT_HIGH(PIN_B5); // ON - Right Light output
OUTPUT_HIGH(PIN_C5); // ON - Left Light output
T_OFF4();
else if(input(PIN_B2) == 0 && input(PIN_C0) == 0)
T_OFF4();
Can someone help me? Why Pin C5 doesn't come HIGH state?
Thanks, |
Posted: Wed Sep 15, 2021 2:32 am |
Key here is the data sheet.
If you look at C5, and table 6-3, you will see that the priority on this pin has
the timer0 input taking priority over the standard I/O functions. You need to
turn this off. Setting Timer0, to use the internal clock should disable this
input selection.
setup_timer_0(T0_INTERNAL);
If you look at Register 4-2, you will see that the default on power on, is
to set the T0CS bit to '1', which has the Timer0 input selected. |
