RS-232 and INT_RDA
Sirio
RS-232 and INT_RDA
PostPosted: Fri Jun 27, 2003 9:51 am     Reply with quote
I've got some problems with PIC16F876A and RS-232.
The communication work properly, but sometimes the u stop to receive data from rs-232.
I think is some overrun problem.
#fuses HS,NOBROWNOUT,NOWDT,NOPROTECT,NOLVP,NOPUT
#use delay(clock = 8000000)
#use rs232(baud = 9600, xmit = PIN_C6 , rcv = PIN_C7, ERRORS)
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
The question is:
how to manage and reset rs-232 errors?
Thanks.
Original Post ID: 144515607
R.J.Hamlett
Re: RS-232 and INT_RDA
PostPosted: Fri Jun 27, 2003 10:27 am     Reply with quote
:=I've got some problems with PIC16F876A and RS-232.
:=The communication work properly, but sometimes the u stop to receive data from rs-232.
:=I think is some overrun problem.
:=#fuses HS,NOBROWNOUT,NOWDT,NOPROTECT,NOLVP,NOPUT
:=#use delay(clock = 8000000)
:=#use rs232(baud = 9600, xmit = PIN_C6 , rcv = PIN_C7, ERRORS)
:=#use fast_io(a)
:=#use fast_io(b)
:=#use fast_io(c)
:=The question is:
:=how to manage and reset rs-232 errors?
:=Thanks.
There are two routes.
The first, is to monitor the 'errors' variable, that you have allready specified to use. The second is to go 'DIY'. Have a look at my post about handling an 11byte packet, where I clear the overrun error.
Original Post ID: 144515608
