Software I2C control DAC_MCP4725A0T 32kHz clock
ag6ju
PostPosted: Wed Jun 23, 2021 1:28 pm     Reply with quote
I use software I2C control, ( not hardware I2C on PIC ) and usually run on clock of 32khz to save current consumption.
UI1  SCL_input ( void )
  UI1  ui1_input;
  //  input
  ui1_input = input ( CLK );
  return( ui1_input );
void SCL_output ( UI8 ui8_state  )
  switch ( ui8_state )
    case I2C_IO_low:
      output_low ( CLK );
    case I2C_IO_high:
      output_high ( CLK );
    case I2C_IO_float:
      output_float ( CLK );
    default:
  } //  switch ( ui8_state )
}  // void SCL_output ( UI8 ui8_state , UI8  ui8_i2c_select )
UI1  SDA_input ( void )
  UI1  ui1_input;
  ui1_input = input ( DAT );
void SDA_output ( UI8 ui8_state  )
    case I2C_IO_low:
      output_low ( DAT );
    case I2C_IO_high:
      output_high ( DAT );
    case I2C_IO_float:
      output_float ( DAT );
    default:
}  // void SDA_output ( UI8 ui8_state , UI8  ui8_i2c_select )
void i2c_start_1 ( void )
  //  start condition
  //delay_cycles ( 20 );    //  5uS at 16 MHz
  //delay_cycles ( 200 );    //
  //delay_us ( I2C_DELAY_US );
  delay_us ( 10 );
  //delay_ms ( 2 );
  SDA_output ( I2C_IO_low );  // SDA -- LOW
  //delay_ms ( 2 );
  delay_us ( 10 );
  SCL_output ( I2C_IO_low );  // SCL -- low
  //delay_ms ( 2 );
  delay_us ( 10 );
}  //  void i2c_start_1 (
void i2c_stop_1 ( void )
  SDA_output ( I2C_IO_low );   // SDA low
  //delay_ms ( 2 );
  delay_us ( 10 );
  SCL_output ( I2C_IO_high );  //  <<  SCL_output ( I2C_IO_float );  // SCL float
  //delay_ms ( 2 );
  delay_us ( 10 );
  SDA_output ( I2C_IO_high );  //  <<  SDA_output ( I2C_IO_float );   // SDA float
  //delay_ms ( 2 );
  delay_us ( 10 );
}  // void i2c_stop_1 (
void i2c_send_bit ( UI1 ui1_input_01 )
  if ( !ui1_input_01 )
    // LOW
    // OPEN
  //delay_ms ( 5 );
  delay_us ( 3 );
  SCL_output ( I2C_IO_high );  //  <<  SCL_output ( I2C_IO_float );  // clock float
  //delay_ms ( 5 );
  delay_us ( 3 );
  SCL_output ( I2C_IO_low );  // clock low
  //delay_ms ( 5 );
  delay_us ( 3 );
} //  void i2c_send_bit ( UI1 ui1_input_01 )
UI1 i2c_receive_bit( void )
  UI1 ui1_output_01;
  //delay_ms ( 5 );
  ui1_output_01 = SDA_input (  );  //  read SDA pin
  delay_us ( 3 );
  //delay_ms ( 5 );
  delay_us ( 3 );
  return( ui1_output_01 );
} //  UI1 i2c_receive_bit( )
Orange County Calif. USA
http://ag6ju-ipv6.dynv6.net:5950/
PostPosted: Thu Jun 24, 2021 10:07 am     Reply with quote
Why did you write your own software i2c routines ?
CCS has software i2c available as part of the #use i2c library code.
ag6ju
PostPosted: Thu Jun 24, 2021 10:46 am     Reply with quote
two reason, it was from the time PIC did not have I2C interface yet 20 years ago or so. and so I can run it slower clock speed like 32khz clock to save current, many of my project runs on small battery where its current capacity is no more than several hundred microamp.
PostPosted: Thu Jul 01, 2021 6:10 am     Reply with quote
The second 'reason' does not make any sense. The CCS software routines will
be faster for your clock rate.
Given you are showing this 'now', use the CCS routines.
