delilcodes
Modbus - Exception 0C |
Posted: Wed May 12, 2021 1:58 pm |
Hello all,
I am new at Modbus and trying to communicate on PIC processors via RS485. I have using Modbus library. When I started the Proteus simulation this exception returns. Only this exception returns when I choose a different selection.
This is project, i used
https://github.com/worrajak/PICmodbus
This is the catalogue. But i don't understand what's wrong?
https://modbus.org/docs/PI_MBUS_300.pdf
https://preview.redd.it/fkk632qk7jy61.png?width=902&format=png&auto=webp&s=d61d8f1336f578424de9bea0f7a12182361f0068
And this is my code: (Turn on the led)
master:
Code: | #include <master_led_yak.h>
#fuses HS, NOWDT
#use delay(clock=4M)
#define MODBUS_TYPE MODBUS_TYPE_MASTER
#define MODBUS_SERIAL_TYPE MODBUS_RTU //use MODBUS_ASCII for ASCII mode
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_BAUD 2400
#use rs232(baud=9600, UART1, stream=PC, errors)
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_EXT
#define MODBUS_SERIAL_TX_PIN PIN_B1 // Data transmit pin
#define MODBUS_SERIAL_RX_PIN PIN_B0 // Data receive pin
#define DEBUG_MSG(msg) fprintf(PC, msg)
#define DEBUG_DATA(msg,data) fprintf(PC, msg, data)
#include <modbus.c>
#define MODBUS_SLAVE_ADDRESS 0x80
int i;
int8 swap_bits(int8 c)
return ((c&1)?128:0)|((c&2)?64:0)|((c&4)?32:0)|((c&8)?16:0)|((c&16)?8:0)
|((c&32)?4:0)|((c&64)?2:0)|((c&128)?1:0);
void print_menu()
DEBUG_MSG("\r\n1. ledi yak\r\n");
void turnOnLED(){
DEBUG_MSG("LED YAKILACAK\r\n");
if(!(modbus_write_single_coil(MODBUS_SLAVE_ADDRESS,1,TRUE))){
DEBUG_MSG("data: ");
for(i=0; i<(modbus_rx.len); ++i)
DEBUG_DATA("%X",modbus_rx.data[i]);
DEBUG_MSG("\r\n\r\n");
}else{
DEBUG_DATA("<-**Exception %X**->\r\n\r\n", modbus_rx.error);
void display(char c){
switch(c){
case '1':
turnOnLED();
void main(){
char c;
DEBUG_MSG("\r\nInitializing...");
modbus_init();
DEBUG_MSG("...ready\r\n");
do{
print_menu();
c = getc(PC);
fprintf(PC,"\r\n");
display(c);
} while(TRUE);
slave:
Code: | #include <slave_led_yak.h>
#fuses HS,NOWDT
#use fast_io(d)
#define MODBUS_TYPE MODBUS_TYPE_SLAVE
#include <modbus.c>
#define MODBUS_ADDRESS 0x80
/*This function may come in handy for you since MODBUS uses MSB first.*/
//! char c;
set_tris_d(0x00);
int8 coils = 0x00;
int16 event_count = 0;
modbus_init();
while(TRUE){
output_d(coils);
while(!modbus_kbhit());
delay_us(50);
if((modbus_rx.address == MODBUS_ADDRESS) || modbus_rx.address == 0){
switch(modbus_rx.func){
case FUNC_WRITE_SINGLE_COIL: //write coil
if(modbus_rx.data[0] || modbus_rx.data[3] || modbus_rx.data[1] > 8)
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_ADDRESS);
else if(modbus_rx.data[2] != 0xFF && modbus_rx.data[2] != 0x00)
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_VALUE);
//coils are stored msb->lsb so we must use 7-address
if(modbus_rx.data[2] == 0xFF)
bit_set(coils,modbus_rx.data[1]);
bit_clear(coils,modbus_rx.data[1]);
modbus_write_single_coil_rsp(MODBUS_ADDRESS,modbus_rx.data[1],((int16)(modbus_rx.data[2]))<<8);
event_count++;
https://i.hizliresim.com/6f7tzsz.png
https://i.hizliresim.com/d920p52.png
The left one is slave modbus TX and nothing going on.
The upper right one is master rx-tx. My gui for turn on the led.
the bottom right one is slave modbus RX. The information received.
What should i do with this. Can you help me? |
Joined: 01 Jul 2010 Posts: 9133 Location: Greensville,Ontario
Posted: Wed May 12, 2021 2:48 pm |
Quite understandable as it's a Proteus 'simulation'... please read PIC101 sticky...
When you get real hardware 'up and running', let me know....
dluu13
Posted: Wed May 12, 2021 7:09 pm |
If you look at the github you posted, there are pictures there with a RS485 transceiver. I've also only ever used the modbus 485 library with the transceiver in there. I cannot be sure that without the transceiver, something is going wrong. |
