"LVALUE required"
mle
"LVALUE required"
PostPosted: Thu Jun 26, 2003 7:36 am     Reply with quote
I have the following code in my main program:
void main(){
char line1[25], seconds[3], colon[2];
sprintf(colon,"\%c",':');
line1=strcat(seconds,colon); //ERROR HERE
I get an error on the 'strcat' line that says "LVALUE required".
What am I doing wrong?
Thanks,
mle
Original Post ID: 144515574
R.J.Hamlett
Re: "LVALUE required"
PostPosted: Thu Jun 26, 2003 7:47 am     Reply with quote
:=Hello,
:=I have the following code in my main program:
:=void main(){
:=char line1[25], seconds[3], colon[2];
:=sprintf(colon,"\%c",':');
:=line1=strcat(seconds,colon); //ERROR HERE
:=I get an error on the 'strcat' line that says "LVALUE required".
:=What am I doing wrong?
:=Thanks,
:=mle
'LVALUE required', implies that a value type is wrong. The fault, is that 'strcat', returns a pointer to a string, while line1, is allready defined, as a physical array (not a pointer). Though C allows you to use the name of an array as a pointer for the right hand side of an equation, doing it the other way round won't work.
Change your definition to:
char *line1, seconds[3], colon[2];
Original Post ID: 144515575
