PIC16F876A and INT_RDA problem
Khaled
PostPosted: Wed Jun 25, 2003 1:26 pm     Reply with quote
We were using 16F873 the following code was working ok. but when we upgrade to 16F876a by using CCS compiler version 3.16 the INT_RDA becomes not working. Please advise.
My simple code is:
#include <16f876a.h>
#include <string.h>
#include <stdlib.h>
#use delay(clock=3686400)
#use rs232(baud=9600,xmit=PIN_c6,rcv=PIN_c7)
#int_rda
void serial_isr(){
char ch;
disable_interrupts(global);
ch=getc();
printf("rec ok");
putc(ch);
enable_interrupts(global);
main(){
set_tris_c(0x80);
enable_interrupts(int_rda);
while (1) {}
Original Post ID: 144515566
Re: PIC16F876A and INT_RDA problem
PostPosted: Wed Jun 25, 2003 1:58 pm     Reply with quote
:=We were using 16F873 the following code was working ok. but when we upgrade to 16F876a by using CCS compiler version 3.16 the INT_RDA becomes not working. Please advise.
You didn't show your #fuses statement, and that could
be part of the problem.
You're doing several things in your #int_rda function
that are not good.
Instead of using your program, try the one shown in this post.
<a href="http://www.pic-c.com/forum/general/posts/13774.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/13774.html</a>
Change the PIC to 16F877A, change the clock speed to 3686400,
and also change the oscillator type in the #fuses statement
from HS to XT. But don't change anything else. Then try it.
Original Post ID: 144515568
