cbarberis
Joined: 01 Oct 2003 Posts: 172 Location: Punta Gorda, Florida USA
| Question on Flexible "I2C" LCD driver (PCF8574T) |
Posted: Sun Jul 05, 2020 10:05 am |
Flexible "I2C" LCD driver (PCF8574T) by Hugo Silva:
http://www.ccsinfo.com/forum/viewtopic.php?t=54063
For some reason I thought this nice piece of code just translated PCM Programmer's Flexible LCD directly to the I2C stream but apparently it is different and although it works fine it does not support the floats so if I send a printf(lcd_putc" float value = %f", float var); it gives me an error telling me it only supports characters. Is there anyway around this to show floats? |
Posted: Mon Jul 06, 2020 10:13 am |
It's because you got impatient and did this:
| Quote: | | printf(lcd_putc" float value = %f", float var); |
CCS generally doesn't support declaring variables in mid-code.
They do somewhat, but you're pushing it. Don't do this.
If you do it the normal old way, then it compiles:
| Code: | float var;
printf(lcd_putc, "float value = %f", var ); |
cbarberis
Posted: Mon Jul 06, 2020 10:29 am |
Thank you PCM Programmer but actually I was not declaring the variable type inside the printf() command I did it that way to explain that I was using a float for that variable the actual way I have it is as follows:
float var; // global var
then I use this to print to lcd
printf(lcd_putc,"float value - %f",var);
But I get an error that only chars are allowed |
Posted: Mon Jul 06, 2020 11:07 am |
| It compiles fine on vs. 5.094. I suspect you have an older compiler version. |
Posted: Mon Jul 06, 2020 11:33 am |
Post the actual code segment you are using, and the exact full error.
Include line numbers.
I'd suspect you have some other basic syntax error. |
cbarberis
Posted: Mon Jul 06, 2020 12:01 pm |
I am not sure where the error is coming from. I have copied the code segment where the error occurs if I comment out LINE 137 everything compiles just fine and the code works fine on the hardware. Also there seems to be a bunch of continuing errors after that but obviously LINE 137 seems to be the issue, like I said if I comment out this line there are no errors. BTW, I am using PCHD 5.094 which is the latest
BME280_readTemperature(&temperature); // read temperature
Deg_f = Convert_C_to_F(temperature);
lcd_gotoxy(1, 2);
if(temperature < 0)
{ // if temperature is negative
putc('-'); // print minus sign
temperature = abs(temperature); // abs: absolute value
LINE 137 -> printf(lcd_putc, "Temp = "%f DegF",Deg_f); // does not work with the I2C_FlexLCD driver only characters allowed
// printf(lcd_putc,"Temp = %02Lu C, or %02Lu F", temperature / 100,(int32)Deg_f ); // this works fine
BME280_readHumidity(&humidity);
lcd_gotoxy(1, 3);
printf(lcd_putc, "Humidity = %02Lu %%", humidity / 1024);
BME280_readPressure(&pressure);
lcd_gotoxy(1, 4);
printf(lcd_putc, "Pressure = %04Lu Mb", pressure/100);
restart_wdt();
ERRORS:
Compiling C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor on 06-Jul-20 at 13:45
--- Info 300 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.h" Line 12(1,1): More info: Actual Clock is 31822506
>>> Warning 203 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 124(1,1): Condition always TRUE
*** Error 12 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 137(31,32): Undefined identifier f
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 173(22,23): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 173(24,25): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 174(42,43): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 174(44,45): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 178(40,41): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 178(42,43): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 179(32,33): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 179(34,35): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 180(43,44): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 180(45,46): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 183(39,40): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 183(41,42): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 184(43,44): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 184(45,46): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 197(22,23): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 197(24,25): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 203(32,33): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 203(34,35): Illegal C character in input file 0x6E after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 208(39,40): Illegal C character in input file 0x72 after \
*** Error 1 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 208(41,42): Illegal C character in input file 0x6E after \
*** Error 79 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 221(43,44): Expect }
23 Errors, 1 Warnings.
Build Failed. |
cbarberis
Posted: Mon Jul 06, 2020 12:21 pm |
Just wanted to note one more thing if I use the printf() line as such printf(lcd_putc, "Temp = "%3.1f DegF",Deg_f); it brings out the real error which is shown as ERROR # 3 on the error list when I used %f I just got an error indicating the character 'f' was invalid.
| Code: | LINE 137 -> printf(lcd_putc, "Temp = "%3.1f DegF",Deg_f); // does not work with the I2C_FlexLCD driver only integers allowed
//printf(lcd_putc,"Temp = %02Lu C, or %02Lu F", temperature / 100,(int32)Deg_f ); // this works fine
COMPILATION ERRORS:
Compiling C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor on 06-Jul-20 at 14:09
*** Error 3 "C:\Picomp\FILES\Bartek\BME280-SENSOR\WeatherSensor.c" Line 137(31,35): Only integers are supported for this operation
Joined: 01 Jul 2010 Posts: 9608 Location: Greensville,Ontario
Posted: Mon Jul 06, 2020 1:54 pm |
hmm...
I think there should be a " after .1F and before DefgF"...
I only see 3 ", and shouldn't there be 4 of them ?
cbarberis
Posted: Mon Jul 06, 2020 2:15 pm |
Jay and the rest of you guys, thank you for enlightening me to the fact that this was just a simple stupid syntax error that I just could not see.
This works --->. printf(lcd_putc, "Temp = %3.1f DegF",Deg_f);
This CANNOT work --->. printf(lcd_putc, "Temp = "%3.1f DegF",Deg_f);
The problem although obvious was invisible to me, there should have never been a " inside string delimiter as you can see on the line that gives me the compilation error with the " just before %3.1f
And YES, to print out a floating numeric format of XX.X it should be %4.1f
I guess my eyes and brain are not connecting too well.
Posted: Mon Jul 06, 2020 2:41 pm |
Hay it's dang near 100*F here in Ontario, gotta be hotter 'down south', so I understand the 'glaring eyes - see nothing wrong' syndrome.
it gets worse the older you get and a 1/2 a dead finger doesn't help either.
wished I'd taking 'touch typing ' in high school but for guys to take it ,that was frowned upon.
dluu13
Posted: Mon Jul 06, 2020 3:27 pm |
| Hmm... Which IDE are you using? Won't there be syntax highlighting in most IDEs nowadays that would make it pretty obvious if you've added an extra quotation mark somewhere, or missed any brackets and stuff? |
cbarberis
Posted: Mon Jul 06, 2020 3:45 pm |
| Using the latest IDE version 5.094 from CCS. There is some syntax high lighting to show variables and things of that sort but I have never seen any highlighting take place when you enter a wrong expression or just do something stupid like I did. You must be using a more advanced IDE like MPLABX |
dluu13
Posted: Mon Jul 06, 2020 3:54 pm |
Yes, I have been using MPLAB X.
I also use programs like notepad++ or Sublime Text for quick editing of code. They also have decent syntax highlighting. |
Posted: Tue Jul 07, 2020 12:31 am |
We have all done this.
Spent ages tracking down a line that would not compile. Turned out that
two lines before I had typed a ':' instead of a ';'.
All too common I'd afraid...
Good thing was that posting the code allowed 'eagle eyed Jay' to find
the fault.  |
