can invert the PWM signal?
ortegahernandes
PostPosted: Thu Jul 02, 2020 5:45 pm     Reply with quote
Can invert the PWM signal?
Instead of starting positive, start negative for one of the PWM
setup_compare (1, COMPARE_PWM | COMPARE_TIMER2);
setup_compare (2, COMPARE_PWM | COMPARE_TIMER3);
to generate the PWM.
PIC: dsPIC33FJ16GS504
PostPosted: Thu Jul 02, 2020 7:01 pm     Reply with quote
Depends on the PIC and the PWM peripheral but of course the easy 'cheat', that any PIC can use ... is to just swap the 'off' and 'on' values....
