Posted: Thu Jun 18, 2020 3:08 am |
Er. If you are using an external quartz, you should not be using ACT.
ACT is to tune the internal clock so that it is synchronised to an external
source.
You have to disable ACT in the clock setup to use what I suggested, but
in your case, you can not/should not be using that anyway.
In your case, how is the unit powered?. There is an issue if the supply
rail rises slowly, that the internal PIC reset cannot then cope. There is
a specification for the maximum rise time for the supply, and if this is
not met, the only solution is an external MCLR circuit. |
