PrinceNai
18f46k22 UART problem |
Posted: Sun Feb 16, 2020 7:08 am |
Dear Sirs,
I'm making a test project with 18F46K22 (internal oscillator) and HC-12 serial to wireless modules. Everything is on one board, the first HC-12 is on UART1 and the second is on UART2. Both are initialized to 9600 baud, same channel, same function mode, same power. My uarts are defined like this:
#use rs232(baud=9600,parity=N,UART1,bits=8,stream = PORT1,errors)
#use rs232(baud=9600,parity=N,UART2,bits=8,stream = PORT2,errors)
My receive interrupt routines are like this:
#INT_RDA
void RDA_isr(void)
tmp=getc(PORT1); // get received char and thus also clear interrupt flag
buffer[next_in]= tmp; // move received char to the appropriate place in buffer
++next_in; // increment IN pointer
if(next_in==BUFFER_SIZE) { // if we have 32, go back to 0
next_in=0;
and the second:
#INT_RDA2
void RDA2_isr(void)
tmp2=getc(PORT2); // get received char and thus also clear interrupt flag
UART2_buffer[next_in_UART2]= tmp2; // move received char to the appropriate place in buffer
++next_in_UART2; // increment IN pointer
output_toggle(LED);
if(next_in_UART2 == UART2_BUFFER_SIZE) { // if we have 16, go back to 0
next_in_UART2 = 0;
I'm sending a string over from uart1 to uart2 every second in main:
const char GAME[] = "TEST\r\n";
while(TRUE){
UART1_Send(GAME);
My problem is that when it goes over the air, I get only the first two characters of the string in UART2_buffer, over and over. No nulls, nothing. If I connect TX from uart1 to RX of uart2 directly, everything works as expected. I have a serial-usb adapter connected, listening to the traffic. I have correct string going to the transmitter and, that is what confuses me, also the correct string coming out of the receiver and going to RX2 (that is where I listen with a terminal). It doesn't work on 3,3V, nor with 5V (here levels might be wrong). I tried different oscillator speeds, no change. Is it possible I have some kind of baud rate problem? If so, how can I detect that?
Regards,
Samo |
Posted: Sun Feb 16, 2020 7:28 am |
Show us the UART1_Send routine.
Two characters, sounds like the routine is returning as soon as the UART
transmit buffer goes full, rather than looping till all the data is loaded.
From a 'standing start', the UART hardware can accept two characters. |
Posted: Sun Feb 16, 2020 7:29 am |
Post your main(). |
PrinceNai
Posted: Sun Feb 16, 2020 7:43 am |
#include <i_transmit.h>
#INCLUDE <ctype.h>
#BYTE RCSTA2 = 0xF71
//#define LED PIN_A5
#define LED PIN_B5
#define HC12_SET PIN_E0
#define HC12_SET_2 PIN_E1
// Set of AT commands. I need 4 commands:
const char AT[] = "AT\r\n"; // Every AT command starts with "AT". Answer = "OK"
const char CHANNEL_COMMAND[] = "AT+C0"; // set channell, the module returns "COK+C0XX"
const char FU[] = "AT+FU3\r\n"; // set function. the module returns "AT+0K" NE, "OK+FU3"
const char POWER[] = "AT+P5\r\n"; // set power level. the module returns "OK+P1"
const char VERSION[] = "AT+V\r\n"; // get version. the module returns version
const char HC12_SLEEP[] = "AT+SLEEP\r\n"; // put the module to sleep. current consumption is 22uA
const char UART_MODE[] = "AT+U8N1\r\n";
const char UART_SPEED[] = "AT+B9600\r\n";
const char GAME[] = "TEST\r\n"; // send info to receiver that the game has finished
char CHANNEL_SELECT[5];
int8 Counter = 0;
char tmp;
int8 HC12_State = 0; // state variable
int8 HC12_Response = 0;
enum {NO_RESPONSE, OK_RESPONSE, CHANNEL_OK_RESPONSE, POWER_OK_RESPONSE, FUNCTION_OK_RESPONSE, SPEED_OK_RESPONSE}; // answers from HC_12
#define CORRECT_ANSWER 1
#define WRONG_ANSWER -1
signed int8 Response;
#define BUFFER_SIZE 16 //create 16 byte large buffer
char buffer[BUFFER_SIZE];
int8 next_in = 0; //max. next_in = BUFFER_SIZE -1 !!!!!
#define UART2_BUFFER_SIZE 60 //create 16 byte large buffer
char UART2_buffer[UART2_BUFFER_SIZE];
int8 next_in_UART2 = 0; //max. next_in = BUFFER_SIZE -1 !!!!!
char tmp2;
int8 HC12_Receiver_Get = 0; // state variable
char DIP_STATE;
int8 Game_Completed_Message = 0;
int8 Send_Game_Message = 0;
// ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
void UART1_Send(char *s);
void UART2_Send(char *s);
// determine channel with respect to DIP switch setting
void Determine_Channel(void){
if(DIP_STATE == 0){
CHANNEL_SELECT = "01\r\n";
else if(DIP_STATE == 1){
CHANNEL_SELECT = "07\r\n";
else if(DIP_STATE == 2){
CHANNEL_SELECT = "13\r\n";
else if(DIP_STATE == 3){
CHANNEL_SELECT = "19\r\n";
else if(DIP_STATE == 4){
CHANNEL_SELECT = "25\r\n";
else if(DIP_STATE == 5){
CHANNEL_SELECT = "31\r\n";
else if(DIP_STATE == 6){
CHANNEL_SELECT = "37\r\n";
else if(DIP_STATE == 7){
CHANNEL_SELECT = "43\r\n";
else if(DIP_STATE == 8){
CHANNEL_SELECT = "49\r\n";
else if(DIP_STATE == 9){
CHANNEL_SELECT = "55\r\n";
else if(DIP_STATE == 10){
CHANNEL_SELECT = "61\r\n";
else if(DIP_STATE == 11){
CHANNEL_SELECT = "67\r\n";
else if(DIP_STATE == 12){
CHANNEL_SELECT = "73\r\n";
else if(DIP_STATE == 13){
CHANNEL_SELECT = "79\r\n";
else if(DIP_STATE == 14){
CHANNEL_SELECT = "85\r\n";
else if(DIP_STATE == 15){
CHANNEL_SELECT = "91\r\n";
else{
//------------------ Send command or data to UART1 -----------------------
void UART1_Send(char *s) // Send command or data string
while(*s) { // as long as you don't encounter NULL
fputc(*s++, PORT1); // send characters to selected UART1
void UART2_Send(char *s) // Send command or data string
fputc(*s++, PORT2); // send characters to selected UART1
// iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
#INT_EXT
void EXT_isr(void)
#INT_TIMER0
void TIMER0_isr(void)
#INT_RDA2
void RDA2_isr(void)
// if((RS232_ERRORS & 0x04)==0x04){
if((RS232_ERRORS)){
delay_cycles(1);
output_toggle(LED);
next_in_UART2 = 0;
#INT_RDA
void RDA_isr(void)
next_in=0;
#INT_TIMER1
void TIMER1_isr(void)
delay_cycles(1);
// end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_
output_high(LED); // turn off LED
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32); //cca. 200 ms overflow
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); //65,5 ms overflow
clear_interrupt(INT_EXT); // prevent external int from firing at once
enable_interrupts(INT_EXT_H2L);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RDA2);
DIP_STATE = input_c();
DIP_STATE = DIP_STATE & 0b00001111; // mask upper four bits
Determine_Channel(); // get the desired channel from DIP switches
delay_cycles(1);
// init the first HC-12
output_low(HC12_SET); // put HC_12 in command mode, able to receive AT commands
delay_ms(200); // wait for HC_12 to enter command mode
UART1_Send(AT); // query module for life signs
delay_ms(200);
UART1_Send(AT);
delay_ms(200);
UART1_Send(AT);
delay_ms(200);
UART1_Send(AT);
delay_cycles(1);
delay_ms(200);
UART1_Send(CHANNEL_COMMAND); // send fixed part of the command
UART1_Send(CHANNEL_SELECT); // send variable channel select part + CR + NEWLINE
delay_cycles(1);
delay_ms(200);
UART1_Send(FU);
delay_cycles(1);
delay_ms(200);
UART1_Send(POWER);
delay_cycles(1);
output_high(HC12_SET); // exit command mode
delay_ms(200); // wait a bit for the module to safely enter UART mode
// end first HC-12 init
// init the second one
output_low(HC12_SET_2);
delay_ms(200);
UART2_Send(AT); // query module for life signs
delay_ms(200);
UART2_Send(AT);
delay_ms(200);
UART2_Send(AT);
delay_ms(200);
UART2_Send(AT);
delay_cycles(1);
delay_ms(200);
UART2_Send(CHANNEL_COMMAND); // send fixed part of the command
UART2_Send(CHANNEL_SELECT); // send variable channel select part + CR + NEWLINE
delay_cycles(1);
delay_ms(200);
UART2_Send(FU);
delay_cycles(1);
delay_ms(200);
UART2_Send(POWER);
delay_cycles(1);
output_high(HC12_SET_2); // exit command mode
while(TRUE){
UART1_Send(GAME);
h file:
#include <18f46k22.h>
#device PASS_STRINGS = IN_RAM //copy all the strings to RAM to allow access with pointers
#device ADC=10
//#FUSES NOEXTOSC //External Oscillator not enabled
#FUSES PUT //Power Up Timer
//#FUSES LPBOR //Low-Power Brownout reset is enabled
//#FUSES BORV27 //Brownout reset at 2.7V
#device ICD=TRUE
#use delay(internal=4000000)
//#pin_select U1TX = PIN_C4
//#pin_select U1RX = PIN_C5
//#use rs232(baud=9600,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=HC-12,errors)
PrinceNai
Posted: Fri Feb 28, 2020 1:33 pm |
Dear Sirs,
Today I built a second, identical board. The same firmware loaded to both, HC-12 connected to Uart1. They are chatting without a glitch. The only thing that comes to my mind is the presence of a debugger (Pickit3) with the use of both Uarts.
Regards,
Samo |
Joined: 01 Jul 2010 Posts: 9503 Location: Greensville,Ontario
Posted: Fri Feb 28, 2020 4:08 pm |
you need to compile in 'release' mode for the 'real world'. Any 'debugger' has to change fuses, adds code for 'testing' purposes..... |
PrinceNai
Posted: Sat Feb 29, 2020 7:10 am |
Done. I only have one Pickit3 at hand, so one board is programmed in release mode (both #FUSES DEBUG and #device ICD=TRUE removed) and the second one in debug mode. Works. |
Posted: Sat Feb 29, 2020 9:20 am |
Read the DEV revision ID on the faulty board. There is a UART erratum that
only applies to revision A2 of the chip. Might well cause your problems. |
