Control motor brushless ccs c
Charles Francês
PostPosted: Sat Feb 29, 2020 3:01 pm     Reply with quote
Hello guys from CCS C How are you? I'm studying brushless motors and I'm having trouble understanding this code. Could someone explain to me how this code works on bldc motors with hall sensor? and if possible I would like to control your vocation! Laughing Rolling Eyes
I have a hard time understanding because I'm new.
// Controle de motor BLDC detectado por CD-ROM com código CIC PIC16F877A CCS
#include <16F877A.h>
 #fuses SH, NOWDT, NOPROTECT, NOLVP
 #device ADC = 10
 #use  atraso (relógio = 8000000)
 #use fast_io (B)
 #use fast_io (D)
int8 hall;
int8 MoveTable[8] = {0, 33, 6, 36, 24, 9, 18, 0};
int16 value;
#INT_RB                                       // RB port interrupt on change
void rb_isr(void){
  hall = (input_b() >> 4) & 7;
  output_d(MoveTable[hall]);
  clear_interrupt(INT_RB);
void main(){
  output_b(0);                                // PORTB initial state
  set_tris_b(0xF3);
  port_b_pullups(TRUE);                       // Enable PORTB internal pull-ups
  output_d(0);
  set_tris_d(0);
  setup_adc(ADC_CLOCK_DIV_16);                // Set ADC conversion time to 16Tosc
  setup_adc_ports(AN0);                       // Configure AN0 as analog
  set_adc_channel(0);                         // Select channel 0 input
  setup_timer_2(T2_DIV_BY_16, 250, 1);        // Set PWM frequency to 500Hz
  setup_ccp1(CCP_OFF);                        // CCP1 OFF
  delay_ms(100);                              // Wait 100ms
  while(TRUE){
    if(!input(PIN_B0)){                       // If RB0 button pressed
      if(input(PIN_B2)){                      // Check if motor is already running
        disable_interrupts(INT_RB);
        output_d(0);
        output_low(PIN_B2);                   // RB2 LED OFF
    if(!input(PIN_B1)){                       // If RB1 button pressed
      if(!input(PIN_B2)){                     // Check if motor is already running
        output_high(PIN_B2);                  // RB2 LED ON
        clear_interrupt(INT_RB);              // Clear RB IOC flag bit
        enable_interrupts(INT_RB);            // Enable PORTB IOC
        setup_ccp1(CCP_PWM);                  // Configure CCP1 as a PWM
        output_d (MoveTable [hall]);
    if (input (PIN_B2)) {
      read_adc (ADC_START_ONLY);
      while (! adc_done ());                     // Aguarde até a conversão concluir o
      valor = read_adc (ADC_READ_ONLY);        // Leia o valor ADC
      set_pwm1_duty (value);                   // Definir ciclo de trabalho PWM
PostPosted: Sat Feb 29, 2020 5:23 pm     Reply with quote
this is a problem...
I think 'valor' is 'vaue' in another language ?
I believe that's a 'stepper' motor that is being controlled by port D of the PIC. You need to decode which port pins are controlling the 4 winding and hopefully there is a transistor buffer between the PIC and the motor !
PostPosted: Sat Feb 29, 2020 7:52 pm     Reply with quote
I believe this is the website that he got the code from:
https://pic-microcontroller.com/sensored-brushless-dc-bldc-motor-control-pic16f877a-microcontroller/
It has a schematic. It's not great, it doesn't zoom in. But you can see
that PWM comes out on CCP1, which is what the code is using.
The website explains how it works. I have provided a link below
that translates the website into Portuguese so he can easily read it:
https://translate.google.com/translate?hl=en&tab=wT&sl=auto&tl=pt&u=https%3A%2F%2Fpic-microcontroller.com%2Fsensored-brushless-dc-bldc-motor-control-pic16f877a-microcontroller%2F
PostPosted: Sun Mar 01, 2020 12:53 am     Reply with quote
and (of course), a 'stepper' motor, and a BLDC motor are very similar things.
The BLDC is analogous to a 3 phase stepper motor, where the PWM being
fed to the phases is modulated to give a smooth motion instead of moving
in 'steps'. They are optimised for smooth motion, instead of step 'accuracy'.
The waveforms required are very similar. You can actually drive a
BLDC like a stepper, and a stepper like a BLDC. However efficiency will
plummet.....
Charles Francês
PostPosted: Sun Mar 01, 2020 10:07 am     Reply with quote
Thanks! Charles
