I2C FORCE_HW
gjs_rsdi
I2C FORCE_HW
PostPosted: Fri Jan 31, 2020 4:38 am     Reply with quote
Hi
I initialize I2C as below:
#use I2C(MASTER, Slow=50000, I2C1, FORCE_HW, STREAM=I2CPORT)
#use I2C(MASTER, Slow=50000, I2C1, STREAM=I2CPORT)
I checked both LST files and they are identical except the two lines above
My question is:
Need to specify FORCE_HW or not if I am using the port name?
Best wishes
Joe
PostPosted: Fri Jan 31, 2020 4:51 am     Reply with quote
No.
Using the physical port name on all of the peripherals (SPI, UART, I2C),
is equivalent to specifying the hardware pins, _and_ specifying 'FORCE_HW'.
gjs_rsdi
PostPosted: Fri Jan 31, 2020 5:43 am     Reply with quote
Thank you Ttelmah, helpful like always Smile
Best wishes
Joe
