Conditional Expression operator ?:
Goto page 1, 2  Next
PostPosted: Fri Nov 04, 2005 4:29 am     Reply with quote
expr ? expr1 : expr2 should return either expr1 or expr2 depending on expr, correct?
If that is true, then could someone please explain why
printf(lcd_putch, "%d: %s\n", fNum++, i < 16 ? codes0[i] : codes1[i - 16]);
gives a Bad expression syntax error when it is compiled. both, codes0 and codes1 are arrays of strings.
I've tried every combination of surround the expressions with paretheses as well as surrounding the whole statement, but nothing seems to work.
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Nov 04, 2005 4:51 am     Reply with quote
try changing %s in %c, you are sending a character, not a string...
further I should personally change i < 16 into (i < 16)
just for the readability
I don't know if this helps., but I hope so...
Good luck
PostPosted: Fri Nov 04, 2005 5:23 pm     Reply with quote
they are arrays of strings, so I need the %s. I tried various combinations of parethenses (the way you suggested and also around the whole thing), but nothing seems to work.
PostPosted: Fri Nov 04, 2005 5:59 pm     Reply with quote
I need the %s.
Older versions of the compiler do not support "%s".
I tested this with PCM vs. 2.734 and it gives an error.
It compiles OK with PCM vs. 3.235.
With older versions of the compiler, you print a string
by passing the name of the array directly to printf(),
as in: printf(array);
So I suggest that you break up your printf statement
into two statements, as shown in the code below.
The following program displays:
55: Hello World
#include <16F877.H>
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
void lcd_putch(char c)
putc(c);
int fNum;
char array[20];
fNum = 55;
printf(lcd_putch, "%d: ", fNum++);
strcpy(array, "Hello World");
printf(lcd_putch,  array);   // This line displays the array.
PostPosted: Fri Nov 04, 2005 6:20 pm     Reply with quote
if I have
printf(lcd_putch, "%d: %s\n", fNum++, codes0[i]);
it works just fine.
I'm fairly certain the problem is in the ?: statement.
PostPosted: Fri Nov 04, 2005 6:22 pm     Reply with quote
Post your compiler version. It's given at the top of the .LST file,
which will be in your project folder. It will be a number like 3.191, etc.
PostPosted: Fri Nov 04, 2005 6:27 pm     Reply with quote
3.181
PostPosted: Fri Nov 04, 2005 6:39 pm     Reply with quote
You're going to have to post a test program, because that line
compiles for me with no errors with PCM vs. 3.181.
In your test program, make sure you post all #include, #fuses,
and #use statements, as well as all variable declarations.
PostPosted: Fri Nov 04, 2005 6:51 pm     Reply with quote
#device *=16
#include<stdlib.h>
#FUSES XT, NOPROTECT, NOWDT, NOLVP, NOBROWNOUT
#use Delay(clock = 4000000)
#include "lcdDriver.c"
#include "codes.c"
   int i;
   for(i = 0; i < 30; i++)
      printf(lcd_putch, "%d: %s\n", i, i < 16 ? codes0[i] : codes1[i - 16]);
codes.c contains two arrays of strings (codes0 and codes1).
I appreciate you taking the time to help.
oops...there should be "#include "16F877A.h"" above all that
PostPosted: Fri Nov 04, 2005 6:54 pm     Reply with quote
here is the exact error I get:
*** Error 22 "H:\C drive\Desktop\School F05\seniord\PIC\test\displayTest.c" Line 18(68,69): Bad expression syntax -1 is not 0..65535
PostPosted: Fri Nov 04, 2005 7:05 pm     Reply with quote
PostPosted: Fri Nov 04, 2005 7:12 pm     Reply with quote
codes.c was rather long so I made this instead
#device *=16
#include<stdlib.h>
//#include "codes.c"
   const char a[2][5] = {{"1234"}, {"5678"}};
   int i;
      printf(lcd_putch, "%d: %s\n", i, i < 16 ? a[0] : a[1]);
dyeatman
PostPosted: Fri Nov 04, 2005 7:56 pm     Reply with quote
Reading this post from earlier today might give you some insight into your problem:
http://www.ccsinfo.com/forum/viewtopic.php?t=25028
PostPosted: Fri Nov 04, 2005 8:20 pm     Reply with quote
ah...apparently it doesn't like the fact that the char array is prefaced with "const". If I take the const out in the example I posted it works. That still leaves me with a problem, though. my codes.c file has the two multi-dimensional char arrays, one of them is 16x12 and the other is 14x12. If I have "const" in front of both of them, I can't use the ?: operator. If I take the "const" out, I get a subscript out of range error.
I guess I'll just have to use an if statement rather than the ?:
Thanks for the help
Goto page 1, 2  Next
Page 1 of 2
