| MassaM
				| Single Digit 7 Segment Display with Increment/Decrement |
				|  Posted: Thu Jul 18, 2019 5:27 am |   |
				|  	  | Code: |  	  | /*
 Tutorial:   Single Digit 7 Segment - Increment and Decrement with buttons and display/output
 Compiler:   CCS-C-PIC - PCWHD Version 5.076
 Author:     MassaM SDC (Solutions Development Consultancy), June 2019
 Contact:    Reach me on,
 Facebook:    https://www.facebook.com/massam.sdc
 Youtube:     https://www.youtube.com/channel/UCbgiHBouih1yzir6Y1zX2VA
 Chip:       PIC16F877A@4Mhz
 #include <16f877A.h> // include the MCUs main header/definitions file
 #fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD // MCU setup the fuses
 #use delay(clock=4Mhz)  // set the oscillator/clock to 4 Mhz
 #byte TRISB = 0x86 //identify TRISB
 #byte TRISC = 0x87 //identify TRISC
 #byte PORTB = 0x06 //identify PORTB
 #byte PORTC = 0x07 //identify PORTC
 #bit TRISB0 = TRISB.0   // bit0 of TRISB
 #bit TRISB1 = TRISB.1   // bit1 of TRISB
 #bit SW_INC = PORTB.0   // bit0 of PORTB
 #bit SW_DEC = PORTB.1   // bit1 of PORTB
 void main() // main application start
 //                  numbers in hex
 // 0  ,  1  ,  2  ,  3  ,  4  ,  5  ,  6  ,  7 ,  8  ,  9
 int digit[]={0x3F, 0x06, 0x5b, 0x4F, 0x66, 0x6D, 0xFD, 0x7, 0xFF, 0x6F};
 signed int count = 0; // initial count is 0
 int switch_state = 1; // initial switch state is high
 TRISB0 = 1;  // Port B bit 0 is input
 TRISB1 = 1;  // Port B bit 1 is input
 TRISC = 0;  // Port C all are outputs for 7 Segments
 SW_INC = 1;// initial port B bit 0 is high
 SW_DEC = 1;// initial port B bit 1 is high
 PORTC = digit[count]; // initial Port C is set to display digit 0
 while(TRUE) // inifite/forever loop
 if( SW_INC == 1 && SW_DEC == 1)  // if both buttons are at high state
 switch_state = 1; // set the switch state flag to 1 as high
 if(switch_state == 1) // check if switch state flag is still at 1 as high
 if(SW_INC == 0)   // if Increment switch was pressed and in low state
 switch_state = 0; // set the switch state flag to 0 as low
 count++; // add 1 to count
 if(count > 9)  // if count reached nine,
 count = 0;  // then reset to zero
 PORTC = digit[count]; // display/output the count as 7 segment digit
 delay_ms(10);  // delay for 7segment refresh time
 if(SW_DEC == 0) // if Decrement switch was pressed and in low state
 count--; // minus 1 from count
 if(count < 0)  // if count reached zero,
 count = 9;  // then reset to nine
 } // switc_state == 1
 } // while
 } // main
 Next edition will be with a 74HC164 to use only 2 pins of MCU. Stay tuned!
 Hope this helps!
 while(!dead)
 keepLearning();
