vtrx
18F4550 PORT E0,E1 |
Posted: Sun Jun 30, 2019 12:12 pm |
I do not know why E0 and E1 are not functioning properly as input.
E1 stopped reading and E0 blended with E1.
Can it be some peripheral set?
I'm starting the ports like this:
Code: | #use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
Code: | setup_psp(PSP_DISABLED);
SETUP_ADC( ADC_OFF );
setup_spi(FALSE);
SETUP_CCP1(CCP_OFF);
SETUP_CCP2(CCP_OFF);
port_b_pullups(true);
set_tris_a(0b11111111);
set_tris_b(0b11111111);
set_tris_c(0b11111111);
set_tris_d(0b11111111);
set_tris_e(0b11111111); |
Code: | #fuses XTPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL1,CPUDIV1,VREGEN,MCLR,CPB,CPD //4MHZ,USB-48MHZ,CPU-48MHZ |
Posted: Sun Jun 30, 2019 12:42 pm |
Post the code that reads the pins on PortE. Also post what external
circuits are connected to those pins.
Ideally, post a complete, but very short test program that shows the
problem. Don't post code fragments. |
vtrx
Posted: Tue Jul 02, 2019 3:14 pm |
Solved.
The trail linking the E0 pin was broken.
But why E0 without 5v, would disrupt E1? |
Joined: 01 Jul 2010 Posts: 9163 Location: Greensville,Ontario
Posted: Tue Jul 02, 2019 4:17 pm |
without seeing a schematic it's hard to tell however according to ..
... you've enabled the weak pullups on PortE.
Jay |
